Just received a couple of these MultiSensors and they came with v1.7 firmware. The motion sensor enable/disable settings have changed which means the "Settings" section for your device in the Z-Wave Plug-In .112 is wrong.
Parameter 4 has changed to enable/disable the motion sensor.
Parameter 4 = 0 - Disable
= 1 thru 5 sets sensitivity with 5 being most sensitive.
Once you set this parameter the sensor will show Disabled in Settings but it's really not. Homeseer might want to re-visit the settings section to reflect the new firmware. If you use the settings and set the motion sensor to enable the sensor behaves a little weird.
The technical documentation for all the parameters for version 1.7 can be found here: https://s3.amazonaws.com/cdn.freshde...lication%2Fpdf
