Homeseer Windows->RPi3 Migration
    I've seen this issue in a few threads on here but I never saw the resolution. When migrating from Windows to Linux Homeseer, I see this error on startup after restoring the backup. The version is 3.0.0.318 on both Windows and Linux:
    HomeSeer Linux starting...
    04:59:51:1759:[Database]->Opening (Mode=Read Only) up HomeSeer LOG database /home/pi/HomeSeer/Logs/HomeSeerLog.hsd
    04:59:51:5492:[Startup]->Config folder has been restored from backup.
    04:59:52:2640:[Startup]->Data folder has been restored from backup.
    04:59:52:2859:[Startup]->Scripts folder has been restored from backup.
    04:59:52:3086:[Startup]->Loading Settings
    04:59:52:6337:[Warning]->HomeSeer was not shut down successfully the previous time it was started.
    04:59:56:6278:[Startup]->Settings Loaded.
    05:00:09:3590:[Startup]->
    05:00:09:3829:[Startup]->********************************************************************************
    05:00:09:3863:[Startup]->          HomeSeer version 3.0.0.318 Edition: HS3 Standard Starting Now
    05:00:09:3882:[Startup]->********************************************************************************
    05:00:09:3909:[Startup]->
    05:00:09:5042:[Startup]->Creating Class Objects...
    05:00:09:5094:[Startup]->COM port classes started.
    05:00:09:5198:[Startup]->Application interface class started.
    05:00:09:5421:[Startup]->Web server class started.
    05:00:09:5461:[Startup]->E-Mail SEND class started.
    05:00:09:5483:[Startup]->E-Mail RECEIVE class started.
    05:00:09:5646:[Startup]->Plug-In Interface class started.
    05:00:09:5697:[Startup]->Local voice recognition class started.
    05:00:09:5802:[Startup]->Database SAVE process started.
    05:00:09:5818:[Startup]->Loading configuration file ...
    05:00:09:6283:[Database]->Opening (Mode=Read Only) up HomeSeer database /home/pi/HomeSeer/Data/HomeSeerData.hsd
    05:00:14:4403:[Database]->Loading Devices...
    05:00:14:4565:[Load Config]->127 total devices loaded.
    05:00:14:4640:[Load Config]->Loading Event Groups...
    05:00:14:4828:[Error]->DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib
    05:00:14:4844:[Warning]->Unable to load event group, name: Lights
    05:00:14:4869:[Error]->DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib
    05:00:14:4879:[Warning]->Unable to load event group, name: Garage Doors
    05:00:14:4902:[Error]->DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib
    pi@raspberrypi:~/HomeSeer $ mono --version
    Mono JIT compiler version 3.2.8 (Debian 3.2.8+dfsg-10)
    None of the events can be restored. Other than that it seems to run properly and can save new events. Anyone know the resolution? Thanks!
    You might try updating your mono installation to V4.x
    Sent from my SM-G935U using Tapatalk
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      Ah yes, thanks, that did eventually solve it. It's a little tricky to get mono 4.XX on Raspbian, since the Debian repos provide 3.2.8. The following link has instructions to add the mono repos directly:
      http://www.mono-project.com/docs/get...install/linux/
      Luckily they do work on RPi3, but it's a chore to get all of the packages to upgrade (some of the 3.2.8 class libraries seem to have stuck around an interfered in a different way).
      Here's what you want to see:
      pi@raspberrypi:~ $ mono --version
      Mono JIT compiler version 4.8.1 (Stable 4.8.1.0/22a39d7 Wed Apr 12 12:47:01 UTC 2017)
        Thank you for this response, I am migrating from Windows to Ubuntu 14.04, and this also helped solve my problem! I was very close to giving up and going back to Windows 32 bit.
        Oddly enough, I installed mono 5 without knowing that was a thing... I wonder if that's why some of my devices are not acting right. Anyway, it's a lot better than 3!
