  #201
Old October 14th, 2015, 08:50 AM
Valkilane Valkilane is offline
What i've done in the past when things got messed up on the IOS side:
delete the IOS homebridge data (privacy-homekit) but also in de config.json - Bridge section changed the "name", "username" & "port".
Stipus, thanks for all the effort!
Originally Posted by askme View Post
I am running into an error in which Homebridge showed up as an accessory in MyTouchHome, but on setup ran into some error. Now it no longer shows up as an accessory no matter the reboot of all parties. There are several references to this issue on the Homebridge git site that reference a bad entry in the Homekit DB that needs to be cleared out. Not sure how to do that.
Has anyone seen the same thing?
  #202
Old October 14th, 2015, 10:19 AM
stipus stipus is offline
Originally Posted by TomTom View Post
Stipus, if the Homeseer platform is modified by you, I assume it needs to be re-downloaded from github? Or are the modification you make for new devices in the config file.? If the platform needs to be downloaded again, any idea on how to do that on Linux/Pi ? If you use the instruction given for initial install "git clone https://" command it says folder/file already exist. TIA
Sent from my iPhone
I always posted the last platform version to this thread. You could download it from the board, and just replace homeseer.js in the homebridge/platforms directory. New platform versions are always compatible with older configure files. I added many parameters but they are always optional.
stipus
  #203
Old October 14th, 2015, 10:46 AM
Malosa's Avatar
Malosa Malosa is offline
Super Seer
Angry
first of all , thanks for your message
but i did that , and added the path variables , but i get a bunch of errors now ,
installed everything like on the tutorial , i dont know what im doing wrong now
PHP Code:
LINK fatal error LNK1181cannot open input file 'C:\OpenSSL-Win64\lib\libeay
32.lib'
[C:\Users\Home Security System\Desktop\homebridge\node_modules\HAP-Node
JS
\node_modules\ed25519\build\ed25519.vcxproj
PHP Code:
c:\users\home security system\desktop\homebridge\node_modules\mdns\src\mdns.hpp
(32): fatal error C1083Cannot open include file'dns_sd.h'No such file or
directory (..\src\dns_service_browse.cpp) [C:\Users\Home Security System\Deskto
p
\homebridge\node_modules\mdns\build\dns_sd_bindings.vcxproj]
directory (..\src\dns_sd.cpp) [C:\Users\Home Security System\Desktop\homebridge
dns_service_enumerate_domains.cpp
  dns_service_get_addr_info
.cpp
c
directory (..\src\dns_service_get_addr_info.cpp) [C:\Users\Home Security System
\Desktop\homebridge\node_modules\mdns\build\dns_sd_bindings.vcxproj]
dns_service_process_result.cpp
c
directory (..\src\dns_service_enumerate_domains.cpp) [C:\Users\Home Security Sy
stem
dns_service_ref.cpp
npm ERR
Windows_NT 6.1.7601
npm ERR
argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\
node_modules\\npm\\bin\\npm-cli.js" "install"
npm ERRnode v4.2.1
npm ERR
npm  v2.14.7
npm ERR
code ELIFECYCLE
npm ERR
telldus@0.0.9 install: `node-gyp configure build`
npm ERR! Exit status 1
npm ERR
npm ERRFailed at the telldus@0.0.9 install script 'node-gyp configure build'.
npm ERRThis is most likely a problem with the telldus package,
npm ERRnot with npm itself.
npm ERRTell the author that this fails on your system:
npm ERR!     node-gyp configure build
npm ERR
You can get their info via:
npm ERR!     npm owner ls telldus
npm ERR
There is likely additional logging output above.
npm ERRPlease include the following file with any support request:
npm ERR!     C:\Users\Home Security System\Desktop\homebridge\npm-debug.log
C
i also did everything with administrator mode and changed permissions , but i get a bunch of red errors (no such directory from files in homebridge folder node_modules)
Check your Environment and PATH variables. It looks like it is getting confused. Also check the privileges you are running with in case that is an issue.
Windows setup has been problematic. If you installed from the Vera Zip file, that was all prebuilt. To get the new version with Homeseer, you will need to rebuild which requires more pre-reqs installed (Python, Git, NPM, Visual Studio, etc).
Good luck
HS3Pro 3.0.0.435 on windows 7 ultimate X64 on hp quadcore laptop 8 GB. 687 Devices, 480Events
  #204
Old October 14th, 2015, 11:02 AM
askme askme is offline
That and a reboot did it for me. Thanks.
And obligatory: Stipus, thanks for all of this.
  #205
Old October 14th, 2015, 11:21 AM
Still working on this
In the config.json, I have a couple of questions:
Under "bridge", do the name, username, port, or pin matter? Or are they arbitrarily simulating a non-existent HW device? I have found no doc on them and anything seems to work.
Under "platform", is the the IP:Port of homeseer's web Server port? or its JSON Control port. I am having trouble connecting to devices and trying to narrow down the possible issues.
Thanks.
  #206
Old October 14th, 2015, 11:40 AM
PHP Code:
32.lib'
JS
PHP Code:
p
.cpp
c
c
stem
dns_service_ref.cpp
npm ERR
Windows_NT 6.1.7601
npm ERR
npm ERRnode v4.2.1
npm ERR
npm  v2.14.7
npm ERR
code ELIFECYCLE
npm ERR
npm ERR
npm ERR
npm ERR
C
First of all, let me just clarify that I gave up on Windows shortly after the point you are at, that said, I think you are having problems with dependencies. I had to install a number of additional Visual Basic and Windows SDK's to get past that point. Check your "Reference Assemblies" directory under WIndows.
I saw another poster indicate they needed also needed OpenSSL installed.
  #207
Old October 14th, 2015, 11:53 AM
Malosa's Avatar
Super Seer
thanks for the reply :
i know its a problem only with the telldus@0.0.9 install script 'node-gyp configure build'.
i searched another topic of other people and i installed a lower version of node 0.10.x , still no luck
with the all in one package the old one it worked normal
here is the debug log
PHP Code:
0 info it worked if it ends with ok
1 verbose cli
'C:\\Program Files\\nodejs\\\\node.exe',
1 verbose cli   'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
1 verbose cli   'run',
1 verbose cli   'start' ]
2 info using npm@1.4.28
3 info using node
@v0.10.40
4 verbose node symlink C
:\Program Files\nodejs\\node.exe
5 verbose run
-script 'prestart''start''poststart' ]
6 info prestart homebridge@0.1.1
7 info start homebridge
@0.1.1
8 verbose unsafe
-perm in lifecycle true
9 info homebridge
@0.1.1 Failed to exec start script
10 error homebridge
@0.1.1 start: `DEBUG=* node app.js || true`
10 error Exit status 1
11 error Failed at the homebridge
@0.1.1 start script.
11 error This is most likely a problem with the homebridge package,
11 error not with npm itself.
11 error Tell the author that this fails on your system:
11 error     DEBUG=* node app.js || true
11 error You can get their info via
11 error     npm owner ls homebridge
11 error There is likely additional logging output above
12 error System Windows_NT 6.1.7601
13 error command
"C:\\Program Files\\nodejs\\\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "run" "start"
14 error cwd C:\Users\Home Security System\Desktop\homebridge
15 error node
-v v0.10.40
16 error npm
-v 1.4.28
17 error code ELIFECYCLE
18 verbose
exit [ 1true
installed windows 7 sdk , still no luck , i hope someone can help me please
  #208
Old October 14th, 2015, 01:16 PM
PHP Code:
1 verbose cli
3 info using node
@v0.10.40
5 verbose run
@0.1.1
8 verbose unsafe
9 info homebridge
10 error homebridge
13 error command
15 error node
-v v0.10.40
16 error npm
-v 1.4.28
18 verbose
exit [ 1true
While I don't think it will solve you problem, you can dump Teldus (and most other platforms/Accessories you don't use) out of the package.json and node_accessories directory to avoid having to compile them.
  #209
Old October 14th, 2015, 01:34 PM
Malosa's Avatar
Super Seer
ok what can i delete from there , i only want homeseer and sonos ..
get an new error
PHP Code:
npm WARN package.json wemo@0.2.1 No repository field
  #210
Old October 14th, 2015, 01:44 PM
Post
get an new error
PHP Code:
The reason I suggest I don't think it will help as the most complex dependencies are in the core modules.
I would bet you can dump safely the following.
"ad2usb": "git+https://github.com/alistairg/node-ad2usb.git#local",
"carwingsjs": "0.0.x",
"chokidar": "^1.0.5",
"color": "0.10.x",
"eibd": "^0.3.1",
"elkington": "kevinohara80/elkington",
"harmonyhubjs-client": "^1.1.4",
"harmonyhubjs-discover": "git+https://github.com/swissmanu/harmonyhubjs-discover.git",
"lifx-api": "^1.0.1",
"lifx": "git+https://github.com/magicmonkey/lifxjs.git",
"node-hue-api": "^1.0.5",
"node-icontrol": "^0.1.4",
"node-milight-promise": "0.0.x",
"tough-cookie": "^2.0.0",
"sonos": "0.8.x",
"telldus": "0.0.9",
"telldus-live": "0.2.x",
"teslams": "1.0.1",
"unofficial-nest-api": "git+https://github.com/hachidorii/unofficial_nodejs_nest.git#d8d48edc952b049ff6320ef99afa7b2f0 4cdee98",
"wemo": "0.2.x",
"wink-js": "0.0.5",
"komponist" : "0.1.0",
"yamaha-nodejs": "0.4.x",
  #211
Old October 14th, 2015, 01:51 PM
Malosa's Avatar
Super Seer
jesus this is so crap right now
lets hope stipus can help out
check this log after deleting
PHP Code:
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.Cpp.Platform.t
argets
(44,5): error MSB8020The builds tools for v120 (Platform Toolset 'v12
0'
cannot be foundTo build using the v120 build toolseither click the Proj
ect menu
or right-click the solution, and then select "Update VC++ Projects..."
Install v120 to build using the v120 build tools. [C:\Users\Home Security Sys
tem
\Desktop\homebridge\node_modules\HAP-NodeJS\node_modules\ed25519\build\ed255
19.vcxproj
PHP Code:
C:\Users\Home Security System\Desktop\homebridge\node_modules\HAP-NodeJS\node_mo
dules
\srp\node_modules\bignum>node "C:\Program Files\nodejs\node_modules\npm\bin
\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js"
configure build
(nodechild_processoptions.customFds option is deprecated. Use options.stdio
instead
Building the projects in this solution one at a timeTo enable parallel build,
please add the "/m" switch.
argets
0'
ect menu
tem
\Desktop\homebridge\node_modules\HAP-NodeJS\node_modules\srp\node_modules\bi
gnum
\build\bignum.vcxproj]
gyp ERRbuild error
gyp ERR
stack Error: `msbuildfailed with exit code1
gyp ERR
stack     at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\
npm\node_modules\node-gyp\lib\build.js:267:23)
gyp ERRstack     at emitTwo (events.js:87:13)
gyp ERRstack     at ChildProcess.emit (events.js:172:7)
gyp ERRstack     at Process.ChildProcess._handle.onexit (internal/child_proces
s
.js:200:12)
gyp ERRSystem Windows_NT 6.1.7601
gyp ERR
command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodej
s\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "bui
ld"
gyp ERRcwd C:\Users\Home Security System\Desktop\homebridge\node_modules\HAP-N
odeJS
\node_modules\srp\node_modules\bignum
gyp ERR
node -v v4.2.1
gyp ERR
node-gyp -v v1.0.1
gyp ERR
not ok
mdns@2.2.10 install C:\Users\Home Security System\Desktop\homebridge\node_modu
les
\HAP-NodeJS\node_modules\mdns
node-gyp rebuild
C
dules
\mdns>node "C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin\\..\.
rebuild
instead
argets
0'
ect menu
tem
\Desktop\homebridge\node_modules\HAP-NodeJS\node_modules\mdns\build\dns_sd_b
indings
.vcxproj]
gyp ERRbuild error
gyp ERR
gyp ERR
s
.js:200:12)
gyp ERR
s\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
odeJS
\node_modules\mdns
gyp ERR
node -v v4.2.1
gyp ERR
node-gyp -v v1.0.1
gyp ERR
not ok
ed25519@0.0.3 install C:\Users\Home Security System\Desktop\homebridge\node_mo
dules
node-gyp rebuild
C
dules
\ed25519>node "C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin\\.
rebuild
instead
argets
0'
ect menu
tem
19.vcxproj
gyp ERRbuild error
gyp ERR
gyp ERR
s
.js:200:12)
gyp ERR
odeJS
gyp ERR
node -v v4.2.1
gyp ERR
node-gyp -v v1.0.1
gyp ERR
not ok
npm ERR
curve25519@1.1.0 install: `node-gyp rebuild`
npm ERR
npm ERRFailed at the curve25519@1.1.0 install script.
npm ERRThis is most likely a problem with the curve25519 package,
npm ERR!     node-gyp rebuild
npm ERR
npm ERR!     npm owner ls curve25519
npm ERR
npm ERRSystem Windows_NT 6.1.7601
npm ERR
s\\node_modules\\npm\\bin\\npm-cli.js" "install"
npm ERRcwd C:\Users\Home Security System\Desktop\homebridge
npm ERR
node -v v4.2.1
npm ERR
npm -v 1.4.28
npm ERR
code ELIFECYCLE
npm ERR
not ok code 0
C
"color": "0.10.x",
"eibd": "^0.3.1",
"sonos": "0.8.x",
"telldus": "0.0.9",
"teslams": "1.0.1",
"wemo": "0.2.x",
"wink-js": "0.0.5",
  #212
Old October 14th, 2015, 02:22 PM
Those errors are MSBuild erorrs indicating that it cannot find or cannot build key components. They have to do with your toolchain environment. You need to verify that NPM's build routines can find the right compilers and libraries.
Stipus was stymied by the same thing and shifted to another platform. ewilliams however, claims to have solved it on Win32 at least and I think is your best bet.
I gave up, installed VirtualBox (free), Turnkey Linux (free), followed the various Homebridge install guides and was up and running pretty quickly.
askme
  #213
Old October 14th, 2015, 02:42 PM
Malosa's Avatar
Super Seer
its to frustrating...
i think i gonna quit this , its not working , its impossible to install this on windows
  #214
Old October 14th, 2015, 04:20 PM
http://stackoverflow.com/questions/1...annot-be-found
  #215
Old October 14th, 2015, 04:49 PM
ewillems ewillems is offline
Guys, please be patient, I have a working version on Windows ready to rolling out... I just need some spare time to publish it .
  #216
Old October 14th, 2015, 05:21 PM
The real hero (well, and Stipus).
  #217
Old October 14th, 2015, 05:24 PM
The latest HomeSeer platform V0.8 is now available from the homebridge repository.
HomeSeer platform roadmap:
- Add offEventGroup and offEventName to each HomeSeer event, so that switch on <event name> and switch off <event name> can run 2 different HomeSeer events
- Add Hue and Sat support to lightbulbs
- Better Door support
- Add GarageDoor, Window and WindowCovering support
- Add lock support
- Add Security System support
Anything else ?
  #218
Old October 14th, 2015, 05:29 PM
Do you have an idea about what we missed ?
We all tried to compile under Windows without success...
So far I tried:
install python 2.7.10
install Visual Studio Express 2013
install GIT
install Bonjour SDK for Windows
install open-ssl
install Node.js
install Homebridge
But npm install still fails !
  #219
Old October 14th, 2015, 06:12 PM
So far I tried:
install GIT
install open-ssl
install Node.js
install Homebridge
The only thing I didn't realize until I moved over to Linux was that if you blow away the entire node_modules directory, it forces a re-pull, and re-build over the entire stack. That solved a ton of version/dependency issues for me on Linux, and i wondered if I shouldn't have tried that on Windows.
  #220
Old October 15th, 2015, 02:50 AM
Malosa's Avatar
Super Seer
wow thanks man !!!!
Siri integration Jakob.Sand HomeSeer General Discussion Area 32 January 6th, 2017 04:11 PM
Homekit and Homeseer jayman13 HomeSeer General Discussion Area 30 July 16th, 2016 10:48 PM
Homekit - Homeseer bridge? kkkk HomeSeer General Discussion Area 2 January 24th, 2015 03:07 AM
Got Siri Working with HomeSeer! mark_anderson_us HS2 / HSPRO 238 August 8th, 2013 02:04 PM
Apple TV integration with Homeseer Steve Q Audio / Video and Infra-red (IR) Discussion 4 March 25th, 2010 03:01 PM
