  #81
Old October 11th, 2015, 02:54 PM
stuckinesc stuckinesc is offline
I just sent you all the Status/Graphics pages for my thermostat... let me know if you did not get them.
Thanks.
  #82
Old October 11th, 2015, 03:08 PM
stipus stipus is offline
Thank-you. I'll try to implement a new 'thermostat' type !
stipus
  #83
Old October 11th, 2015, 03:21 PM
joegrace13's Avatar
joegrace13 joegrace13 is offline
Originally Posted by maverick View Post
As I have spent some hours getting this working (and thanks for the help in here), I'll just post my setup. Running a Turnkey Linux on ESXi 5.1 box).
Install Turnkey Linux Node edition: https://www.turnkeylinux.org/nodejs
Commands:
apt-get update
apt-get upgrade
apt-get install node
node -v
apt-get install libavahi-compat-libdnssd-dev
apt-get install avahi-daemon
git clone https://github.com/nfarina/homebridge.git
cd homebridge
npm install
cd homebridge
npm run start
pico config.json
Enjoy :-)
/Mav
Fallowed this to a tee yet:
module.js:340
throw err;
Error: Cannot find module 'HAP-NodeJS'
The README in homebridge states I need NodeJS v 0.12.x or better. The most up to date version from apt-get is 0.10.20.
  #84
Old October 11th, 2015, 03:38 PM
New temperature sensor options
Here is (attached) a new version of the HomeSeer platform with the following changes:
1) Added a temperatureUnit=F or C option to temperature sensors
If you have a HomeSeer temperature device with temperature in fahrenheit, configure the HomeBridge device this way:
PHP Code:
"ref":111,                               // HomeSeer device reference (mandatory)
"type":"TemperatureSensor",    // HomeKit Device Type
"name":"Bedroom Temp",        // HomeKit Name (optional - default = HomeSeer device name)
"temperatureUnit":"F"             // HomeSeer device unit (optional - default = "C")
2) Added support for negative temperatures.
Negative temperatures were shown as 0.0°C in HomeKit applications with previous versions of the platform. This has been fixed.
Attached file removed, as it is now included in the latest homebridge distribution
  #85
Old October 11th, 2015, 03:40 PM
joegrace13's Avatar
module.js:340
throw err;
Running:
npm update
Seems to have cleared this up. I'm not familiar with npm.
  #86
Old October 11th, 2015, 03:57 PM
joegrace13's Avatar
Ok so I'm running homebridge now with this simple config:
"bridge": {
"name": "Homebridge",
"username": "xxx",
"port": 51826,
"pin": "xxx"
"platforms": [
"platform": "HomeSeer",
"name": "HomeSeer",
"host": "http://xxx",
"accessories":[
"ref":214,
"type":"Lightbulb"
"ref":734,
"type":"Fan"
"accessories": [
What app do I need to install on my phone to make use of this?
  #87
Old October 11th, 2015, 04:10 PM
I use MyTouchHome
  #88
Old October 11th, 2015, 04:18 PM
joegrace13's Avatar
I'm using that as well. The server says it is running:
EventedHTTPServer Server listening on port 51826 +0ms
But nothing shows up in MyTouchHome. Just Searching...
Are there firewall or any other networking issues I need to deal with with this basic TurnKey Linux install?
  #89
Old October 11th, 2015, 04:29 PM
I am running homebridge on my HS3 system and I have the following in my config.json file...
"bridge": {
"username": "CC:22:3D:E3:CE:30",
"port": 51826,
"pin": "031-45-154"
...and with in platforms [] I have...
"name": "HomeSeer",
"host": "http://127.0.0.1:8080",
Your HS IP and port depends on your system
  #90
Old October 11th, 2015, 04:53 PM
joegrace13's Avatar
Got it working... I put back the default username and pin. I thought those needed to be changed.
  #91
Old October 11th, 2015, 05:29 PM
joegrace13's Avatar
But then I start adding accessories...
Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: 0012f4f2-cd73-4bf6-8ed0-6ba182637d59
  #92
Old October 11th, 2015, 05:30 PM
jayman13 jayman13 is offline
Hey stipus, thanks for doing this. Is there any way to use it with a homeseer user and password? Mine is user/pass protected...
  #93
Old October 11th, 2015, 05:36 PM
joegrace13's Avatar
Sigh... I just have to rename all the devices in my house.
  #94
Old October 11th, 2015, 05:37 PM
No you can add a name property for each device in the config file
  #95
Old October 11th, 2015, 05:38 PM
You are the first to ask.... I'll do this
  #96
Old October 11th, 2015, 05:39 PM
joegrace13's Avatar
Hmm... I'll have to take a look at that. Is there a list of all properties we can define someplace?
  #97
Old October 11th, 2015, 05:47 PM
At the beginning of the file platforms/HomeSeer.js
You can always override the HomeSeer name using the name property, such as in the following example:
"ref":9,
"type":"Lightbulb",
"name":"Lampe Orange",
"onValue":101
  #98
Old October 11th, 2015, 05:48 PM
joegrace13's Avatar
Never mind... RTFM. Sorry, I'm looking at your HomeSeer.js Example.
Thank you Stipus
  #99
Old October 11th, 2015, 06:31 PM
  #100
Old October 11th, 2015, 07:22 PM
In fact it already works with HomeSeer authentication.
In the platform configuration you can add the homeseer user and password in the host parameter.
PHP Code:
"host":"http://user:password@ip_address"
I just tested with user stipus and password test
PHP Code:
"platform""HomeSeer",
"name""HomeSeer",
"host""http://stipus:test@192.168.3.4:81",
"accessories":[ .......
Siri integration Jakob.Sand HomeSeer General Discussion Area 32 January 6th, 2017 04:11 PM
Homekit and Homeseer jayman13 HomeSeer General Discussion Area 30 July 16th, 2016 10:48 PM
Homekit - Homeseer bridge? kkkk HomeSeer General Discussion Area 2 January 24th, 2015 03:07 AM
Got Siri Working with HomeSeer! mark_anderson_us HS2 / HSPRO 238 August 8th, 2013 02:04 PM
Apple TV integration with Homeseer Steve Q Audio / Video and Infra-red (IR) Discussion 4 March 25th, 2010 03:01 PM
