They've had this problem before. It was fixed with the 2.2.0.7 build but .11 brought it back. Check your task manager and you may see HS and Itunes both burst to 35% CPU every few cycles. It's enough to slow down your PCI modem if you open the line during a burst.
Itunes is such a memory hog anyway I've just decided to disable the plugin and use the Media Player.
