8/31/2014 6:17:34 PM ~!~Error~!~Unable to start plug-in API: Only one usage of each socket address (protocol/network address/port) is normally permittedStartup Complete, 1 errors detected, check the log for more information.
I'm running the HS3 Pro Trial and the Kinect Plugin Trial version 3.0.0.14.
At the moment, I can't even remove the Plugin from the Plugin management page. I hit the "x" and the screen just refreshes, but it is still there.
I'm also getting **FATAL** errors on the HSTouch Server and Z-Wave Plugins.
The Kinect Plugin and sensor were working quite well yesterday. The only major change I made was hooking up the Insteon Hub to my network and enabling the Insteon Plugin by Mark Sandler.
Let me know if you need anymore information. At this point I think I need to remove the HS3 installation and start again from scratch. Do i just Add/Remove programs and delete all lingering files?
