ImperiHome is a mobile application (Android and iOS) to control home automation systems and connected objects. It is highly customizable and very user friendly.
This plugin is designed to allow ImperiHome to control your HomeSeer system. It automatically scan your devices and events and expose them to the ImperiHome app.
In the current Beta version the following object will automatically be exposed
Moreover the following device types can be manually configured from the config page
Please report any bug.
Please read the User GuideHS3 version 3.0.0.299 or later
Changes to v3.0.0.16
- Fixed locale parsing of double values
Changes to v3.0.0.15
- Fixed problem with thermostats that don't have an ambient temperature device
Changes to v3.0.0.14
- Added support for shutter devices
- Added optional volume parameter for Speak actions and Speak Proxy
- Sorted devices alphabetically in "On/Off devices", "Dimmers", "Door Locks" and "Thermostats" tabs
Changes to v3.0.0.13
- Added "Wake Up" and "View Camera" actions
- Added configuration tabs for "On/Off devices", "Dimmers", "Door Locks" and "Thermostats" in order to be able to filter out the one you don't want to access from IH.
Changes to v3.0.0.12
- Added "Events enabled by default" setting
- Added Cache Rebuild button to avoid having to restart the plug-in.
Changes to v3.0.0.11
- Added support for https
Changes to v3.0.0.10
- Show the setpoint the closest to the current temperature when thermostat has 2 setpoints.
Changes to v3.0.0.9
- Added second setpoint and fan mode for thermostats
- Fixed database error when local language use the coma as decimal separator
- Fixed problem with thermostat using humidity device instead of temperature
Changes to v3.0.0.8
- Added Linux support for historical data graphs for sensors
- Fixed shut down of plugin.
Changes to v3.0.0.7
- Added support for historical data graphs for sensors (only supported on Windows for now)
- Fixed disabled event groups still appearing in the app
Changes to v3.0.0.6
- Added possibility to select/deselect an entire event group
- The system id sent to imperihome is now "HS3 <machine_name> <instance_name>"
Changes to v3.0.0.5
- Added possibility to use the plugin as a Speak Proxy
- Added Events tab in the Config page, from which events can be filtered out.
- Security devices now shows the last change date
Changes to v3.0.0.4
- Added "Speak" and "Go To Dashboard Page" event actions (using Control API, Android only)
- Added "location1 + location2" and "location2 + location1" as possibles options for Groups
- Fixed blank sensor unit reverting to default unit.
- Fixed problem with locale formatting of sensor values
Changes to v3.0.0.3
- Added support for Multi Switch devices (= multiple choice actuators)
- Added option for Generic sensor to display the string status of the device instead of the numerical value.
Changes to v3.0.0.2
- Added support for security devices: Door/Window sensor, Motion sensor, Smoke sensor, Flood sensor, CO2 Alert sensor
- Fixed small bugs.
Changes to v3.0.0.1
- Added support for sensors
- Added support for Locks
- Added optional username/password http authentication
- On/Off devices (any HS device that has On/Off "Control Use")
- Dimmable devices (any HS device that has On/Off and Dim "Control Use")
- Locks (any HS device that has Door Lock/Door Unlock "Control Use")
- Thermostats (any group of HS devices that implement the Thermostat API)
- Events
- Sensors (any HS device that has a numeric value: Temperature, Pressure, etc...)
- Security Devices (any HS device that has 2 status: Opened/Closed, Motion/ No Motion, etc...)
- Multi Switch (Any device that has multiple controls)
- Shutters (Blinds, shades, etc...)
- Cameras
Changes to v3.0.0.9
Changes to v3.0.0.8
Changes to v3.0.0.7
Changes to v3.0.0.6
Changes to v3.0.0.5
Changes to v3.0.0.4
Changes to v3.0.0.3
Changes to v3.0.0.2
- Fixed small bugs.
Changes to v3.0.0.1
