Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old February 28th, 2016, 07:31 PM
sparkman's Avatar
sparkman sparkman is online now
Trigger of apcupsd devices
Hi Philippe,
Should it be possible to trigger from changes of the UPS devices? As an example, I'm trying to create a trigger if the time left drops below a certain value. However, if I select a value, and then collapse the trigger, it always shows a value of 69.3. See screen shot below. Any ideas? I'm running the latest version.
Al
Old February 29th, 2016, 02:28 PM
pcp pcp is offline
Super Seer
Originally Posted by sparkman View Post
Hi Philippe,
Al
Attachment 52550
Attachment 52551
As far as i recall these are just regular devices with values and should allow this. I am not near a hs environment to check. I don't know why hs3 would not let you configure it with these devices.
Old February 29th, 2016, 02:36 PM
sparkman's Avatar
Thanks, can you test it when you get back to your hs environment and let me know if you can replicate it? I believe it used to work with an earlier version of the plugin, and don't know when it stopped working.
Al
Old March 5th, 2016, 09:18 AM
pcp pcp is offline
Super Seer
Al, I did setup a similar event, but cannot reproduce the behavior; see screenshots below. It looks like in your case it is displaying the string of the device value instead of what you entered. For my test, I was using HS3 Pro Edition 3.0.0.243 (Windows). The apcupsd plugin actually does not really matter because these is pure HS3 device trigger setup and the plugin trigger/action are not involved (but for reference I was using my latest apcupsd plugin version 3.2.0.1). I did navigate to other web pages and then back to the event page, reopen the details of the event to verify. In all cases it worked fine for me.
Old March 6th, 2016, 10:31 AM
sparkman's Avatar
Thanks Philippe. I deleted the device and restarted the plugin. With the recreated device, it's now working for me, so not sure what was wrong with it.
Cheers
Al
Old March 7th, 2016, 01:01 AM
sparkman's Avatar
Hi Philippe,
Found an issue related to that event. I restarted HS tonight and when the apcupsd plugin started, that event triggered and shut down the HS server. I had to disable the plugin in settings.ini in order to be able to properly restart HS. Does the plugin reset those values to 0 when it restarts, before updating them to what it gets from the daemon?
Al
Old March 7th, 2016, 07:12 PM
pcp pcp is offline
Super Seer
Funny one . I don't know and the device value and will have to check.
Old March 7th, 2016, 07:33 PM
sparkman's Avatar
Thanks, I was watching the log when it happened Then panic set in for a few moments as I was trying to figure out how I could prevent it from happening over and over again Luckily I have HS3 on a bit of a delayed start which gave me enough time to edit settings.ini before it re-started.
Cheers
Al
Old March 7th, 2016, 07:43 PM
TomTom's Avatar
TomTom TomTom is offline
Al,
Did this happen with the event you setup the event in post number 1( time left)? I was about to setup something similar this weekend, but I'll wait to hear back. This would be a nightmare in my remote setup if it happened.
I finally had someone go into my house a few days ago and wake up my hs pc. Then finally set the timeleft and battery power to -1 in the apcupsd config file. I'll follow this thread...
Hi Philippe,
Al
Tom
Old March 7th, 2016, 07:47 PM
sparkman's Avatar
Originally Posted by TomTom View Post
Al,
Hi Tom, yes it did, and yes, I would not recommend using a similar event until Philippe can confirm the expected behavior.
Cheers
Al
Old March 8th, 2016, 08:10 AM
pcp pcp is offline
Super Seer
I haven't had a chance to look into it. Have you tried adding and and condition to check that the value is let's say greater than 1 in addition?
Old March 8th, 2016, 10:36 PM
sparkman's Avatar
I'm guessing that will work. I restarted the plugin while watching the apcupsd devices and most go to 0 when the plugin is shut down.
Al
Old March 12th, 2016, 04:19 PM
pcp pcp is offline
Super Seer
I looked at the code and yes devices are reset to default values upon disconnect. I will look at changing this for an upcoming version.
Old March 12th, 2016, 04:36 PM
sparkman's Avatar
Old March 15th, 2016, 07:00 AM
pcp pcp is offline
Super Seer
I send a new version to hst this weekend to install in the updater. This should resolve this.
Old March 15th, 2016, 10:25 PM
sparkman's Avatar
Thanks Philippe, that did it!
Cheers
Al
APCUPSD Plug-in for HS2 Discussion pcp Script & Plug-In Library Discussion 3 December 31st, 2015 09:48 AM
apcupsd monitor discussion BootsC5 Script & Plug-In Library Discussion 42 June 3rd, 2014 04:14 AM
APCUPSD devices are not visible in Event configs sparkman APCUPSD Plugin (3P) 4 June 2nd, 2014 11:49 AM
APCUPSD Script beerygaz Jon00's plugins and scripts 3 October 10th, 2010 07:28 AM
apcupsd monitor script BootsC5 Script & Plug-In Library 2 May 11th, 2008 09:53 AM
