Still confused. I've never used scenes, do I need to activate them somewhere?
HomeSeer lighting is Here!
Originally posted by SeaOtter View PostCurrent version is: HS3 ZEE S2 Edition 3.0.0.280
Z-Wave 3.0.1.66
Is there a formal display of a support profile?
I just updated the Z-Wave plugin software and rebooted the ZEE S2 and only see the on/off toggle of the root device. If I go to the z-wave tab for the device I can set the "switch reverse", "LED Mode", and response to "all on, all off commands" thats all that is there.
I think you will have to exclude and re-include your switches now that you upgraded to the .66 version of the Z-Wave plugin to give you the three devices for each switch.
John
Originally posted by jumper4000 View PostHow about this - we create an Event to set the dim level to 1% when the dimmer is set to Off. That will make the bottom LED go back on, right? How much power do you think having it set to 1% will use?
Originally posted by happnatious1 View PostStill confused. I've never used scenes, do I need to activate them somewhere?
Think of the scenes on these switches like any other device that has a state that you can use to trigger events. Like a button press on a minimote. So the switches give you a scene device that can have eight different states: Top tapped once, top tapped twice, top tapped three times, top pressed-held-released, and the same four for the bottom paddle. So you can build eight different events triggering on the eight states for one WD100 switch.
John
Originally posted by rjh View PostI see, I missed the dimmer part. Right, all the leds go off when you turn it off and there is no setting. I will make a note, if we have to update for any other reason I will see if I can get that in there.
Z-Wave 3.0.1.66
Just updated Zwave Plug-In to 66 and Z-Wave Controller went crazy with ZNET spitting out a bunch of errors. Then went to Beta on 71 and that fixed the issue.
(Though on 71, the abort button on my ZNET Android App, no longer works).
Does anyone know how to enter exclusion mode the device?
I had to reset the breaker and press the device to enter it.
But prefer a method where touching the breaker isn't necessary.
Originally posted by happnatious1 View PostI'm confused, I'm trying to run an event using a triple tap and I get this:
The abort button on the iOS app isn't working either. I also can't get the Add New Room option to allow me to type in a new room. It does collapse the pick list and you'd them expect to be able to click into the name space, but wherever you click on that row it doesn't enable editing. At least for me.cheeryfool
Originally posted by macromark View PostYou don't use the Z-Wave scene trigger. You use the trigger 'Device is set to' and then use the central scene device that's created when you add the switch to your system. The device appears in a screen shot from this post: http://board.homeseer.com/showpost.p...9&postcount=15
Whats the difference between scene 1 and scene 2?
Finished the install of all my light switches and am seeing only 3 that have the issue when you power on that the light initially lights, then dims to off and then comes on again. I have somewhere near 30 or so dimmers/switches and companions.
I am liking the scenes you can do with them: In the master bathroom, a double tap up will resume the album I was listening to in LMS and turn lights on. A double down will shut the lights and pause the music.
Scene 1 is a press on the top paddle, scene 2 is a press on the bottom paddle. Look at the scene device on the device management page then press the paddle to see the various scene #'s. You can also look at the status/graphics tab on the scene device, it will list what each scene # is. Think of a scene as a status.
Originally posted by happnatious1 View PostThanks mark, I would never have found that!
Are those 3 devices switches or dimmers?
Originally posted by macrho View PostFinished the install of all my light switches and am seeing only 3 that have the issue when you power on that the light initially lights, then dims to off and then comes on again. I have somewhere near 30 or so dimmers/switches and companions.
