Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old March 5th, 2017, 06:08 PM
mwolter mwolter is offline
No Device Images
Hello,
I am evaluating your plugin on a HomeTroller SEL (linux) and the device images are not appearing. I have verifed the folder the images are directed to does not exist. Do you have a fix for this or a location where the images can be downloaded from?
Old March 6th, 2017, 09:24 AM
pcp pcp is offline
Super Seer
The plugin is Windows only and never tried or supported Linux. Not sure if the case, but I asked Homeseer in the past to ensure the HS3 updater configuration for the plugin is for Windows only.
One or two users tried on Linux if you search the forum threads with more or less success. The icons in a Windows environment are installed when the plugin starts based on the HS3 icon set configuration (there is a Windows script in each of the plugin icon/image directories to do so).
Old March 11th, 2017, 09:15 PM
Oh ok, your plugin actually works fine in linux except for the icons. Had no trouble installing the APCUPSD linux package and your plugin recognized it and is able to obtain info regarding my Cyberpower UPS. Tested the operation and everything appears to work fine.
Icons might be the only part missing, in case you decide to support Linux also.
If you're interested, I'm happy to help with testing.
Old March 12th, 2017, 12:25 PM
pcp pcp is offline
Super Seer
Thanks for the update. MAybe you did already but you could build the image directory (HS3_installation\html\images\apcupsd\status based on the content of the HS3_installation\html\images\apcupsd\contemporary folder and references (symbolic links) built by the script install_icons.bat.
UltraMon Custom Device Type Images (open source images only) Ultrajones UltraMon HSPI 6 March 21st, 2015 10:52 AM
Netcam Images in Device Mgmt & Device Status views JazzmanJohn HS3 / HS3PRO Discussion 0 February 4th, 2014 01:23 PM
Device Images dlover HS3 / HS3PRO Discussion 9 July 28th, 2013 11:29 PM
Images for Device Status. stevene Designer 1 January 17th, 2011 10:16 PM
