After using nexa devices for some time, but found it unreliable,
i just bought 14 zwave battery wall controllers.
Its the duwi wall controller (9) and the duwi wall controller with zwave.me firmware (5). I tought of cource that these "simple" devices was fully supported by HS as HS seems z-wave focused. Which i think is a good thing.
I can get the original duwi controller to work and control the assosiated lights, but i can not make assosiations in HS (Im new with zwave, so the terminology might be off)
The duwi wall controller with zwave.me firmware has a lot of new features, with instant update status of the controlled devices and so on.
You can read more about the device here
http://www.smarthus.info/support/man.../ZME_05443.pdf
The problem is that this device can not be used with HS.
Note, i have not tried this my self, but it is reported on this board and domoticaforum.eu.
As i see it, there is two choices
1) Ask for suppport in HS
2) Use Vera controller as a primary
(full support for the zwave.me firmware)
Regarding the second alternative
1) Is it possible?
2) I use HS touch - can i control the lights fully using HS Touch. Scenes/events, instant status updates, polling etc.
3) What might be the downsides of doing this?
4) Other comments?
1) Is it possible?
4) Other comments?
