Mark,
As you know I recently started using your plugin again. Have to say nice job!
I did notice a couple of items to comment on, hope you don't mind:
1. When editing the name / location of a previously added device, if you edit both name and location and hit save changes only the name is saved. You have to go back and change the location and hit save again to get that to save.
2. I migrated from the ISY and there were a lot of old links. I thought when I programmed a device for use with Homeseer this would clean out old links and reset the device. Is there a reason that this wouldn't be the case when adding a device? Or, maybe this could be an option (i.e. it's a pain to go clean all of these up manually).
Thanks again for the great plugin!
