HSTouch
    HSTouch
    How does this plugin work with the HSTouch?
    Can i get like a forecast that i can use on the HSTouch client?
    Any pictures etc on how this works?
    Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
    You can add all text and images into HS touch as you see fit.
    One simple example is attached below.
      Great thank you! Looks good to have a 48h forecast up.
        I cant find any of the devices in HStouch.. I got all the devices working in HS3 and I can see the correct temperature forecast, radarimage, etc, but none of the devices are visible in HStouch.
        Do I need to do anything to make them visible there?
          If the Designer was running when you added the devices to HS, use the refresh button in the Designer to update it's list of devices.
          Mike
            Thanks, but its not that :\ I added the devices last week and I've also tried to create a new project.
            I have looked in the Devices palette and with:
            Elements -> Others -> Image -> StatusTrackingNormal -> HomeSeer devices
            Elements -> Others -> Text -> StatusTra......>
              You should see those in Category 'Weather', Room 'Location-1'. You may want to try restarting the HSTouch Server Plugin.
              Mike
                Thanks Disabling and Enabling the HS Touch plugin solved the problem.
