I regularly backyp my HS3 directory, in case something goes wrong. This has happened, and I copied over my backed up HS3 directory over the actual one (after shutting down HS3). Then I restarted HS3. Everything is working fine, but my radiators and heating behave a little strange, things seem to come on/go off at strange times. I would have thought that they just should work as normal, given that the system time is right ?
Or is there something else I should do to 'resync' the schedules ?
