Motion sensors
    Motion sensors
    Hi there. I had a play around with the plugin using magnetic strip sensors and found that to be fine for what I want.
    My next thing is motion sensors. If I have motion sensors with built in resistors which give different readings depending on state can I use them with this plugin and the pi?
    E.g. no motion detected = 2.2kohms
    Motion detected = 6.4 kohms
    Tamper switch activated = 9kohms
    Readings are just an example rather than exact amounts but you get the idea.
    Is there a resistance reading status I can assign to the gpio in this plugin?
    Thanks in advance :-)
