Kinect?
    Kinect?
    What is this plugin? Is this using the kinect? If so will this be a feature you add to the kinect plugin, or a separate plugin? If separate will it interfere with the current kinect plugin?
    _______________________________________________
    HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
    Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
    Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
    It is a new plugin I'm working on. It will work with any webcam or netcam (including kinect)
    There is a little more information about it in this thread: http://board.homeseer.com/showthread.php?t=170228
      I'm still confused. It seems like you are writing your own algorithm for facial recognition (which is pretty impressive), and yet it is one of the key parts of the kinect SDK. I had thought the plan based on some past comments in kinect threads was to add this to the kinect plugin?
      https://msdn.microsoft.com/en-us/library/jj130970.aspx
        The face tracking SDK for kinect can be used to detect the position of the head and facial expressions, but not so much for facial recognition (i.e identifying a person)
        I'm not writing my own algorithm from scratch, I'm using the OpenCV library which has numerous applications, one of them being facial recognition.
          Thanks for explaining. I still think what you do is impressive. Would both plugins be able to work with the same kinect?
