What I did, use the update feature, after that it was broken.
Tried:
Disable / re-enable plugin > no succes.
Disable plugin, shutdown HSpro, restart HSpro, enable plugin > no succes
Tried deleting and reinstall, only after first disable, and restart of HS i could delete it. Reinstall of 3.0.0.14 > no succes.
I think im now out of options
The log says this:
Tried:
The log says this:
jun-16 22:00:22 Plug-In Finished initializing plug-in Buienradar
jun-16 22:00:22 Error Initializing plug-in(2): Buienradar Instance::String was not recognized as a valid DateTime.STACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
jun-16 22:00:21 Buienradar Initializing plugin Buienradar version 3.0.0.14
jun-16 22:00:21 Info Plugin Buienradar has connected. IP:127.0.0.1:52410
