Installed BLLAN to monitor cameras. I put the cameras in and HS devices were created even though the plug in status says HS devices are not assigned. I turned off power to one camera and can see the ping failures in the log. But the HS device still says the camera is on. How do I get this to work properly?
Please Help
All cameras respond to pings. But that's not the problem. I can see in the log that there are ping failures, but the HS device still shows online and never changes. I need to trigger an event if the cam goes offline.
There may be a HS problem here. Using the BLue Iris plugin, I can see in the log that there is a watchdog failure, but it also doesn't trigger an event like it should.
Originally posted by jrjmpls7 View PostAll cameras respond to pings. But that's not the problem. I can see in the log that there are ping failures, but the HS device still shows online and never changes. I need to trigger an event if the cam goes offline.
There may be a HS problem here. Using the BLue Iris plugin, I can see in the log that there is a watchdog failure, but it also doesn't trigger an event like it should.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by Blade View PostLog a ticket on my site and capture the issue with debug logging turned on in the plugin
Then attach the BLLAN-Detailed.log zipped to the ticket on my site
After deleting and starting over, the other 5 devices are now working and triggering events as they should. I don't know how to fix the 6th one. Any ideas?
Originally posted by jrjmpls7 View PostI deleted all devices and restarted hs. Then put devices in again. Now 5 of six cameras work. But the sixth is very strange. When I put the device in BLLAN, it does not create a new device in HS. Instead, it puts the status string into the device that I use to switch the power off and on. This is the only camera that uses an insteon device to switch the power (is that a clue?). I've deleted and added the camera in BLLAN several times and it always does the same thing.
Thanx
