Ra2 Plug-In Description support Integration 3rd Party Homeseer
    ****** For RA2 Select use the Caseta plugin *******
    Features now working
    See Documentation for more details : RA2 Documentation
    Windows and Linux
    -Multi Instance
    -Config page for IP, Port and creation of the device
    -Creation device by one click
    -Control light and appliance
    -Simulate the PICO_KEYPAD
    -Control SeeTouch_Keypad
    -SeeTouch Table Keypad
    -Grafik Eye
    -Shade up and down
    -Venitian blinds Up/Dpwn/Tilt
    -Control Output
    -Status of the Led of the SEETOUCH_KEYPAD
    -Control Scene of LutronRa2
    -Occupancy now working (will stay in motion until your program timer of the device finish)
    -Remote 4 GROUP_REMOTE
    -RRD-2ANF fan control
    -Timeclock ( Away, Normal, Etc you create)
    -Run the timeclock event you create in RadioRa2
    -Control Thermostat
    -Config page with Option to not change graphics or name of the device to the default of RadioRA2
    -Control Fade and Delay
    Features to come:
    Instructions:
    enable the plug-in
    Go in the config web page
    -enter the IP of the Main Repeater
    -the standard port is 23
    Wait 30 second then click on Create new device.
    Poll your device
    Sometime I need to disable and enable the HSTouch plugin so the device update in HSTouch.
    you should be up and running
    3.0.0.109
    -Add in config the fonction to ungroup or group parent and child, this will help to have the device display correctly in the new mobile apps
    -Add Last for Dim and Shade device, dimmer returns the light from Off to the last level to which it was set.
    -If Ungroup it will group the 2 Venitien Tilt and Raise
    -Plugin with Multi-Instance
    -Fix Pico Scene
    3.0.0.100 Add the User and Password for Telnet in config page
    3.0.0.99 Fix Dim/Raise button on SeeTouch for Programmed Devices
    3.0.0.98 Add Off to Security Phantom Button, Add the Dim and Raise to the SeeTouch
    3.0.0.97 Add checkbox for the Debug Developer Mode Window
    3.0.0.96 Change the icon of the led status and the scene status to be defferent from a light Screen Shot
    3.0.0.95 Change the icon of the led status and the scene status to be defferent from a light Screen Shot
    3.0.0.94 Add the CCI (input) status of the Visor Control Receiver VCRX
    3.0.0.93 Add the ability to control the led of the seetouch in the events
    3.0.0.92 Remove the decimal on Dim light and shade (this can give issue with Google Home)
    3.0.0.91 Fix the Shade command
    3.0.0.90 Add Delay and Fade for each device and also add it to be able to control it in the Events
    3.0.0.89 Add Seetouch Table Keypad, Add compatibility with more lutron switch compatibility, Add log if error when importing
    For all the Button Seetouch, Grafix it will import only if you give a name to your button.
    3.0.0.88 Fix device import if only one MainRepeater
    3.0.0.87 In debug mode it will tell you what device got error if not in HS
    Mar-06 4:52:11 PM LutronRA2 Debug Device SeeTouch does not exist in HS ID: 4 Button: 1
    3.0.0.85 If telnet connection lost will reconnect, include the Grafik Eye
    3.0.0.83 fix some Parent/Child, fix buttons names
    3.0.0.82 include the Venitian blinds, fix icon for Main Repeater
    3.0.0.81 fix issue for new user
    3.0.0.80
    see http://forums.homeseer.com/showthread.php?t=186782
    3.0.0.71
    Fix possible crash
    Fix some issue with Thermostat
    Poll now show value
    3.0.0.70
    Some bug fix
    3.0.0.69
    Thermostat is now incorporate (be sure to set C or F in HS setup page, if you change after creation of the thermostat just do a Poll to change the unit)
    ****Thermostat in HSTouch: temperature and setpoint work with de default Climate screen, the mode and fan are not compatible with that screen
    Fix some buttons alignment
    3.0.0.67
    *** need to click on create all new device in the config to take effect ***
    Add the possibility to run manually the TimeClockEvent from HS3 and have the last time it run
    3.0.0.66
    Fix the TimeClock don't update correctly
    3.0.0.65
    Add the Log function
    Do not log commands from this device:
    3.0.0.63
    -Change Scene and SeeTouch control button
    -Fix Connect Status on the MainRepeater
    3.0.0.62
    -Fix HSTouch now update ststus live
    3.0.0.61
    HS will put it in the Updater page
    Copy automatically the Image in the folder
    Correction for linux so the Image will be in the correct folder
    1.0.0.50
    Please update theImage folder (new image)
    add feature:
    1.0.0.43
    Fix bug
    1.0.0.42
    fix the import device NON_DIM_INC
    1.0.0.42
    fix the import device and convert from old address id to new one
    1.0.0.37
    Fix Plugin didn't start when first time run
    accelerate the live feedback from device
    1.0.0.35
    fix some Bug
    Add the Timeclock ( Away, Normal, Etc you create)
    1.0.0.31
    SeeTouch now have the name of buttons in the events
    Fix the delay of status feedback
    1.0.0.30
    Can now Activate Scene and have the status
    Can control other device with Pico with events
    Pico hold key can be chose in the events
    1.0.0.19
    Fix bug of status not refresh
    Fix some bug for Linux (Linux is not warranty to work)
    1.0.0.17
    Fix bug that prevent to start
    1.0.0.16
    Fix some HSTouch
    1.0.0.15
    Add the SeeTouch
    1.0.0.10
    Add the Shade
