First the SeeKeypad buttons and the Scene(Phantom) will be create only if you have a label name in the RadioRA2.
SeeKeypad:
-action when you press a button:
if you want an event to trigger every time you press it you need to chose "A Device's Value is..." than " changes and becomes"
use the device that have all your label of the SeeKeypad not the status alone of the button
every time you press the button the even will trigger.
-action when the led turn on or off
if you want an event to trigger every time the led status archive (led On = all the RA2 are at the setpoint of that scene, Led Off = at least one of the device of the scene are not at le setpoint) you need to chose "A Device's Value is..." than " changes and becomes"
use the device that have the Led status of the button
every your led change at the status of your scene it will trigger the envent
Scene(Phantom)
First the Phantom is only use by a 3rd Party from Ra2, so you need to have the software RadioRA2 to configure them, with that you can create scene (set multiple device with one press) this is faster reaction than use the Event in HS .
-action when the turn on or off
if you want an event to trigger every time the status archive (On = all the RA2 are at the setpoint of that scene, Off = at least one of the device of the scene are not at le setpoint) you need to chose "A Device's Value is..." than " changes and becomes"
use the device that have the status of the Scene
every your device change at the status of your scene it will trigger the envent
SeeKeypad:
Scene(Phantom)
