Hi Blade,
I am a bit stumped. Ive had BLRadar for some time, but went in to really start using it today. I found my system doesn't seem to be detecting the motion on events anymore, but is detecting the off events. I've checked the the motion sensors (1 in on, 0 is off). The motion sensor in BLRadar is setup to trigger on values. I can activate the motion sensor and the last activity time in BlRadar updates (and the zone device itself shows motion then no motion), however the Active Zone never turns on.
Log attached. Look at device 2115 which is a Envislink motion device. The last Off is fine, the last ON is wrong.
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): ** Finished checking sensor --> 2227
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): ** -----------------------------------------------
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): ** Checking sensor --> 2115
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): Code --> Zone 8
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): Location --> Alarm
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): Name --> Dining Room Motion
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): Type --> Motion Sensor
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): FirstOn --> 5/11/2018 11:30:46 AM
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): LastOn --> 5/11/2018 11:30:46 AM
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): LastOff --> 5/13/2018 6:41:56 PM
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): DeadBattery --> False
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): SensorRecoveryTime --> 60
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): DeadBatteryTime --> -1
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Recovery() started
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Recovery(): * Start of sensor recovery check for Zone 8...
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Recovery(): theSensor.LastOff --> 5/13/2018 6:41:56 PM
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Recovery(): theSensor.LastOn --> 5/11/2018 11:30:46 AM
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Recovery(): no processing... last off is greater than last on so sensor has received its off!
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Recovery(): * End of sensor recovery check for Zone 8
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Recovery() finished
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Dead_Batteries() started
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Dead_Batteries(): * Start of sensor failure check for 2115...
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Dead_Batteries(): dead battery time is NOT enabled for this sensor!
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Dead_Batteries(): * End of sensor failure check for 2115
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Dead_Batteries() finished
5/13/2018 6:42:50 PM : v2.0.139.0 - Check_Sensor_Times(): ** Finished checking sensor --> 2115
Thank you!
Bill
Thank you!
Bill
