Movie Showtimes Discussion
    #16
    Works like a champ.....but :-)
    How can I get the device to show when it was last changed? It has stayed the same date since the day I installed it and the movielisting script.
      #17
      Last Change update
      The attached file should fix the last change status of the movie listing.
      If you want to make the change yourself simply add one line at the end of the script like so:
        strTemp = replace(strTemp, "|sp", " ")
        hs.SetDeviceLastChange strItem, now                  <------ add this line here
        hs.SetDeviceString strItem, strTemp
      end sub
        #18
        Did I mention the attached file that I forgot to attach?
          #19
          Getting that Invalid procedure call....
          I can't exactly say when this started happening, but its been a while. I am trying to remove all RED messages on my log by either removing the offender or fixing it. Used to really like this script and would like to fix it. Does anyone have a working version?
          HTML Code:
          8/19/2013 10:52:19 AM  - Error - Running script, script run or compile error in file: MovieListing.txt5:Invalid procedure call or argument: 'mid' in line 117 More info: Invalid procedure call or argument: 'mid'
