BLRADAR is using aW800Rf32 on Com 5 and RFXrec433 on Com 8. The temps sensors stop receiving updates periodically. I suspect there is an issue with the RFXrec433 but nothing is reported in the HS log. I shutdown the PI and reenbable. The PI reports connecting to the com ports but no other issues. How can I troubleshoot this?
THGR810 / RFXrec433 stops
Originally posted by Blade View PostYes it is static for the RFXCOM receiver
Do you think you can capture the issue with debug logging turned on
Maybe there is an error in the log
Sent from my iPhone using TapatalkRegards,
Andrew B.
For some reason... can't get debug log to work
Turned it on a week ago... log file really didn't grow.
Upgraded to 2.0.95.0 this morning.
Turned plugin off, deleted the log so that i would start from scratch...
Turned plugin back on...
Attached log has activity for first second after turning plugin back on... then nothing... been using palmpads, and tripping x10 motion sensors... but no update to log..
Turned plugin off.. then back on...
adds one line to the log
09/23/2018 04:07:53:109 PM : v2.0.95.0 - **************** Debug Logging DISABLED at 9/23/2018 4:07:53 PM ****************
then nothing...
Also attached my config file.
Any ideas or thoughts are appreciated.
BLRF-Detailed.log.txt
hspi_BLRF.ini.txtRegards,
Andrew B.
Thanks..
Will report back when i get the log workingRegards,
Andrew B.
