Intellichlor message issues
    Spud,
    Was wondering if you could look at the intellichlor code. I have an alarm on my Autelis saying I have a very low salt condition but HS3 is seeing it as low voltage. Let me know if I could provide any more data.
    please set the log level to Debug and post the data sent by the Autelis controller. Thanks
      Let me know if this makes sense.
      Mar-27 12:41:57 PM Autelis DEBUG 1 0 0 5 0 4 Intellichlor--20
      Mar-27 12:41:57 PM Autelis INFO CMD SENT: http://192.168.88.152:80/chem.xml?
      Mar-27 12:41:57 PM Autelis DEBUG 50 13 1 0 0 0 0 0 0 0 1.6.4 1490636497 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 78 100 55 55 56 F 0
      Mar-27 12:41:57 PM Autelis INFO CMD SENT: http://192.168.88.152:80/status.xml?
        well I guess the HS log is filtering out the xml tags or something, so could you instead paste the following url in a browser and post here the xml you get as the response:
        thanks
          <response>
          <chlor>
          <chloren>1</chloren>
          <poolsp>0</poolsp>
          <spasp>0</spasp>
          <salt>5</salt>
          <super>0</super>
          <chlorerr>4</chlorerr>
          <chlorname>Intellichlor--20</chlorname>
          </chlor>
          <ichem/>
          </response>
            I confirmed with the Autelis devs that the error messages were wrong in the plug-in, it's now fixed in version 3.0.0.13 available here
            Thanks for reporting the problem
              The new PI failed to install.
              WARNING: Failed getting InterfaceStatus from Autelis - the interface was not found in the list of active interfaces, the list may need to be refreshed.
              Install/Update of package Autelis Pool Control failed.
                I just figured out the install. Zip file was empty. PI installed. Will be testing
                  Values seem accurate now. I appreciate the quick fix. During your next release, can you add spaces to the returned string on the intelichlor. The string being returned right now is On: VeryLowSalt. Can the "On: be dropped and the message come back as Very Low Salt
                  Heading to the store to pick up the plugin
