I could use some guidance here.
I created an event when the water level sensor is activated after 10 seconds. It triggers to "Push" an Alert and Speak thru Sonos.
When the Level Sensor is activated "Wet" and the timer is greater than 10 seconds the event triggers. However unlike several of my other events this one re-triggers multiple times or every second until the sensor state is "DRY" .....
I only need it to trigger once.... What am doing wrong here? I have several other events that only speak one time when the event is "True"
Devoir
Devoir
