Insteon Hidden Door Sensor (2845-222)
    I just got several of the Insteon Hidden Door sensors. I can tap-add them and the HS Insteon plugin sees them and lists them in the 'config' screen after adding, but no HS3 device is created. I've tried this several times -- no problems with discovery, the plugin reports "programming the device" and then shows it in the config list, but no devices are ever created.
    Am I doing something wrong?
    -M.
    Maybe using the wrong plugin?
    Try Mark's plugin - it works with all things Insteon.
    -BD
      Yes, the HomeSeer Insteon doesn't work with any of the newer devices. Marks plugin is the one to use if you need robust Insteon support.
