Hi I decided to try the IFTTT plug-in to explore the possibilities in combination with iPhone location.
I followed all the instructions and got it working. the IFTTT/ Dropbox part seems to work perfectly. When leaving an area, an txt document is created and placed into dropbox.
Than this file is noticed by the Plugin and the trigger in Hs3 execute an event.
The strange thing is though, that this occurs only once. After the first time the next documents in dropbox seems to be ignored by the plug-in?
So what's wrong here?
[COLOR=#000000]okt-01 13:39:44 [/COLOR] [COLOR=#000000] Event [/COLOR] [COLOR=#000000] Event Trigger "testing test ifttt trigger - leaving" [/COLOR] [COLOR=#000000] okt-01 13:39:43 [/COLOR] [COLOR=#000000] IFTTT [/COLOR] [COLOR=#000000] DEBUG New file leaving.txt found in /ifttt/triggers/leaving/leaving.txt [/COLOR] [COLOR=#000000] okt-01 13:12:15 [/COLOR] [COLOR=#000000] IFTTT [/COLOR] [COLOR=#000000] DEBUG Folder IFTTT/Triggers/leaving is now monitored [/COLOR] [COLOR=#000000] okt-01 13:12:15 [/COLOR] [COLOR=#000000] IFTTT [/COLOR] [COLOR=#000000] DEBUG Folder IFTTT/Triggers/arriving is now monitored [/COLOR] [COLOR=#000000] okt-01 13:12:14 [/COLOR] [COLOR=#000000] Plug-In [/COLOR] [COLOR=#000000] Finished initializing plug-in IFTTT [/COLOR] [COLOR=#000000] okt-01 13:12:14 [/COLOR] [COLOR=#000000] IFTTT [/COLOR] [COLOR=#000000] INFO IFTTT version 3.0.0.3 [/COLOR] [COLOR=#000000] okt-01 13:12:14 [/COLOR] [COLOR=#000000] Info [/COLOR] [COLOR=#000000] Plugin IFTTT has connected. IP:127.0.0.1:61116 [/COLOR]
