I recently hooked up my Google Home with Homeseer and when attempting to change the temperature on a Nest thermostat I get an error code which results in the temperature not being changed. Please see the attached screen shot of the error log.
More detailed description: I activate my Google home via voice, and say, "Set the downstairs thermostat to X degrees" Google home responds, "okay setting the downstairs thermostat to X degrees". Then nothing happens, no temperature change. When I looked in the log file, as you will see, for some reason homeseer is receiving a request for an invalid temperature. Obviously, that is not the temperature I requested, as I'm asking for temperatures that are round numbers only. See attached screenshot of log.
I also sent this same info to Homeseer Support a few days ago. They indicated that they have sent it to Google Home Integration for review, but suggested I also contact the developer saying, " It may be the case that the plugin needs to be adjusted so that the devices it creates are voice control compatible."
Thanks for your help!
Nick
Nick
