This version continues to provide an improved user experience and from a code perspective a significant change in the means to manage the non-plugin and plugin associations with MQTT topics. The dynamic update of fields on the Associations, Manual Pub and Manual Sub have much logic and room for some situations to have not been considered. Let me know if any inconsistencies have been observed.
The database has evolved through the versions and assumptions made before are no longer valid for current design of the plugin. A one-time reconstruction of the database is done on the initial run of V3.2.x.x. This may make the startup appear slow, but it is only once.
The Association table is now only rendered on a button push. This is done to improve page load times. Color coding of the rows has been done to distinguish plugin vs. non-plugin MQTT relationships.
Some discussion on CAPI and non-plugin device control via MQTT is contained at https://forums.homeseer.com/showthread.php?t=194817
The change log at the top of the sticky on this forum discloses other updates that were made
https://forums.homeseer.com/showthread.php?t=192675[/URL]
