Hello,
The sdk talks about a UsesJqAll attribute that can be set to false to speed-up webpage loading. It seems to be meant for use with genpage function.
Can you please provide an example how to use this attribute?
The sdk recommends to use the pagebuilder function instead of genpage. Does this attribute also work with pagebuilder ? Can you please provide sample code ?
Thank you.
Thank you.
