I am new to Homeseer and I am trying to set up voice commands for my Insteon dimmer switch that controls my bedroom fan and voice commands for my bedroom ceiling fan. I think I understand the phrases I need to use but I don't know where to go in the Homeseer menu to set the device property that enables it to accept voice commands. I also don't know where in Homeseer to type in the command phrases. Can anyone help?
Device Commands for Insteon
rcourtney002@ec.rr.comTags: None
Originally posted by rcourtney002@ec.rr.com View PostI am new to Homeseer and I am trying to set up voice commands for my Insteon dimmer switch that controls my bedroom fan and voice commands for my bedroom ceiling fan. I think I understand the phrases I need to use but I don't know where to go in the Homeseer menu to set the device property that enables it to accept voice commands. I also don't know where in Homeseer to type in the command phrases. Can anyone help?Mark
HS3 Pro 4.2.19.5
Thanks mnsandler. I checked the "Voice command" on the device property page but I don't see where I should type in the command phrases to control the lights.
Originally posted by rcourtney002@ec.rr.com View PostThanks mnsandler. I checked the "Voice command" on the device property page but I don't see where I should type in the command phrases to control the lights.
if you create an event, you can then set a voice command to run the event.Mark
HS3 Pro 4.2.19.5
