Originally posted by ilkevinli
View Post
Nest Plug-in - Beta Testing
version 3.0.0.5
In version 3.0.0.5 (available on first post of this thread), I have added a fan device, and I have fixed the implementation of the thermostat API. Now only thermostats will show up in the climate screen in HSTouch, and you will be able to control target temperature from there.
I'm still not sure how the control for fan and mode is supposed to work in the thermostat API, I will ask HST guys.
before starting the new version delete your existing Nest devices, and they will be recreated correctly by the plugin.
Hi Spud,
Not sure about anyone else, but it is still only showing 0's. I followed the directions in the 1st post and deleted the devices before upgrading. I now see the new fan device, but the NEST is not working in the HSTouch climate section. Looks just like the screenshot above.
Originally posted by spud View PostIn version 3.0.0.5 (available on first post of this thread), I have added a fan device, and I have fixed the implementation of the thermostat API. Now only thermostats will show up in the climate screen in HSTouch, and you will be able to control target temperature from there.
I did try that. Not working here. Not sure why it works for you. I just tried on my wifes android phone and it is also showing zeros. If you want, I can give you my login information if you would like to test. Just let me know and I'll PM you.
Do you think it has something to do with me using a custom HSTouch port ?
Originally posted by spud View Postmake sure to completely close your HSTouch client, then restart it so that it reloads all your devices.
It works fine here on my Android device
Originally posted by stech99 View PostGet the following message when I load up the plugin.
**FATAL**: Failed getting InterfaceStatus from Nest - the interface was not found in the list of active interfaces.
Had this on other plugins until I figured out the proper loading. This one is not cooperating.
do you have .NET 4.5 installed?
8/29/2014 11:35:03 AM ~!~Error~!~Starting plug-in exe process: The specified executable is not a valid application for this OS platform.
or am I look at the wrong log? The one from the opening menu? Sorry a newbie to the system.
. . . .net4.5 wont load on the Homeseer xp box I have
Any other suggestions?
Originally posted by stech99 View PostNothing in the log that I can see aside from this
this has been reported by several other users, so I'm going to see if I can make a version that works with .net 4
