I had a PLM working for about 3 years... I thought it died and bought a new one... It's the same 2413U... I'm having the same issues with the new one where it loses communication to the COM port... If I reset the PLM, reset the HS3 software it will work for a few minutes then goes into a cannot connect state... The software tries to reset and sometimes works however seems very unstable. I removed all other com port accessories and even tried changing the com port and still nothing... I also switched USB ports and even replaced the USB cable... Any thoughts as to whether it is a PC issue or a PLM issue?
Ryan
Ryan
