Hi all
I am new to HS and have installed hs2 to test it. I setup 1 (manual trigger) event as a test, it waited for a "test" phrase to be spoken ( speaker client on local machine ) and then replied with a confirmation phrase. It worked fine but when i set the "cannot retrigger for" box to 60 seconds I was able to re trigger the event again within the time ? Should HS have ignored the attempt to trigger the event for the time specified or am i misunderstanding its use.
I have not checked if this only happens with voice commands, I will check when i get home tonight.
Mark.
Mark.
