Is there a way to globally suspend all event processing without disabling all individual events?
Suspending all event processing
I think you'd need to run a script. See GetEventEnumerator in the Help file. There's an example showing how to cycle through all events. You'd need a script for disabling them all, and another for re-enabling them all. But, if you have any disabled at the start, figuring out which ones they are and not enabling them with the second script will take some thought.
Of course, you could also just exit HS. That always suspends the events.Mike____________________________________________________________ __________________
I'm tying to fix a problem with my Ocelot devices. Some are not showing up. Some are showing up but don't respond to status changes from the Ocelot. I tried deleting all the devices so I could simply recreate them but that caused HS to start processing thousands of events that were conditional on the devices. I couldn't do anything but kill the HS task and restore the config file. What I really need is a way to temporarily suspend processing of events while I work on the Ocelot devices. That should be a very simple thing to do. I suspect it is but I just can't find where to do it.
A thought. I've never tried this, so I'll be curious to know what happens if you try it.
On the Events page, select All Groups, then check the box next to the drop down. That should select every event.
Then go to the bottom and select Disable selected events.Mike____________________________________________________________ __________________
