Wiimote plug-in - Not working :(
    I have downloaded the trial of this and I have 2 wii remotes.
    I have run WiiPair.exe which detects the first remote and starts the setup process. Then without warning the console closes and the wiiremote is half setup.
    Then I tried to add the second remote by doing the same thing. Now the second remote is added and the icon appears in the bluetooth driver screen. Then without warning, everything is gone! nothing there.
    What am i doing wrong?
    after messing around for a long time, i now get this on the plugin.
    Plugin: Wiimote Instance: starting...
    Connecting to server at 127.0.0.1...
    Connection attempt #1
    Connected (HomeSeer API 3). Waiting to be initialized...
    INFO Wiimote version 3.0.0.1
    DEBUG Wiimote not found error: No Wiimotes found in HID device list.
    DEBUG No Wiimote found. Is the wiimote paired and turned on?
    INFO Wiimote not found. Is the wiimote paired and turned on?
    DEBUG Wiimote failed to connect: Error reading data from Wiimote...is it connect
    ed?
    DEBUG Wiimote failed to connect: Cannot get attributes of Wiimote device.
      I just tried to do the pairing again from scratch and strangely enough I got some problems too: the device kept disappearing after Windows finish installing the drivers. To fix it I restarted the Bluetooth Support Device service in windows as explained here:
      here is a detailed step by step guide
      - stop plugin
      - restart the Bluetooth Support Service
      - open a console and cd to your HS3/bin/Wiimote dir
      - start Wiipair.exe from this console.
      - press the red button inside the the battery-department of the Wiimote
      you should see something like this:
      - then let windows automatically install the driver for this device
      the leds on the wiimote should keep blinking during this process
      - then start the Wiimote plugin in HS3
      if everything is ok the wiimote should rumble for one second and the first LED should be turned on.
      let me know how it goes
        i get the pair done then see screen shot.
        Could there be an issue doing this over RDP?
          and after a few moments it's gone again.
            Figured it out. When done over RDP it does not work.
            It has to be done from the console, however as soon as I log in remotely over RDP it dies again.
