Well time to put the Megas into a 28" cabinet and get it wired. The whole cabinet will be run off a Car Battery topped up by a trickle charger.
1) I3 PC running HS. Has SSD and external laptop PSU. I'm currently using an invertor but more research to be done to see if I can work out how the ID pin works so I can get rid of the plug pack.
2) Two relay boards
3) Two PWM boards for LED lighting (12 outputs)
4) Two beaglebones, one for the logitech media server and the other for Asterisk PBX
5) GSM modem for text messaging.
The panel can be mounted into a wall cavity to make it look a little neater. Waiting for a 5 port switch for ethernet. Used LOTS of rivnuts for the standoffs. Has been an interesting exercise so far.. More to come :-)
2) Two relay boards
