Hey Jon,
I currently have one computer setup with the Network Monitor and the client installed working great. I have installed the client on a second computer and brought up the webpage Jon00RCCNM.asp and the first time it brought it up I could see all IP addresses on the network. I have tried refreshing several times, clearing the cashe of the web browser (Chrome) and refreshing again, tried a different computer, turned off Windows Defender and I still only get one IP in the list which is the first computer I set up.
What do you suggest I try next?
If there was a network setting that is causing this issue, I assume I wouldn't be able to see everything like I did when I first brought up the web page, correct?
PS. Just tried IE browser just in case and still same result.
Edit:
Just followed the directions in the help file to manually add the client and it has added a device in the HS3 Device page, it shows up in the list referenced above but still not everything is showing up. This is what is showing up in the HS log:
Nov-16 5:02:43 PM Jon00_RCCNM [Device2] Cannot connect to client on port XXXXXX
Nov-16 5:02:41 PM Device Control Device: Utility Jon00 Network Nate PC Client to Ssaver On (Execute Script) by/from: CAPI Control Handler
Nov-16 5:02:30 PM Jon00_RCCNM [Device2] Cannot connect to client on port XXXXXX
Nov-16 5:02:28 PM Device Control Device: Utility Jon00 Network Nate PC to Ssaver On (Execute Script) by/from: CAPI Control Handler
Nov-16 5:02:01 PM Warning File does not exist: C:\Program Files\HomeSeer HS3\html\apple-touch-icon.png
Nov-16 5:02:01 PM Warning File does not exist: C:\Program Files\HomeSeer HS3\html\apple-touch-icon-precomposed.png
Nov-16 5:02:01 PM Warning File does not exist: C:\Program Files\HomeSeer HS3\html\apple-touch-icon-152x152.png
Nov-16 5:02:01 PM Warning File does not exist: C:\Program Files\HomeSeer HS3\html\apple-touch-icon-152x152-precomposed.png
Nov-16 5:01:28 PM HSTouch Server Warning Exception on Value Change callback: Object reference not set to an instance of an object.
Nov-16 5:01:28 PM Jon00_RCCNM Info - Virtual device created for Address: Jon00-NM-N002 with Reference: 796
Nov-16 5:01:28 PM Jon00_RCCNM Logging file Device2Network.log created
Nov-16 5:01:27 PM HSTouch Server Warning Exception on Value Change callback: Object reference not set to an instance of an object.
Nov-16 5:01:27 PM Jon00_RCCNM Info - Virtual device created for Address: Jon00-NM-C002 with Reference: 795
Nov-16 5:01:26 PM Jon00_RCCNM Logging file Device2Client.log created
Also, the only control button I'm able to get working is the WOL. The Shutdown, Restart, Log Off, Lock, Ssaver On, Ssaver Off & Update don't seem to be working on either computer.
Thank you for your help on this.
Edit:
