Thank you! That worked brilliantly! I'm curious to know how that actually worked. I see in the thread that the problem was that HSTouch was rendered pages in IE7 but how did that small registry change fix that? Just wondering.
Screens created with HSTouch
Originally posted by jamesk View PostThank you! That worked brilliantly! I'm curious to know how that actually worked. I see in the thread that the problem was that HSTouch was rendered pages in IE7 but how did that small registry change fix that? Just wondering.
Originally posted by raptorsss View PostI have a traffic page using google traffic maps.
just went to the location I wanted, turned on traffic, and copied the URL into HS Touch in a text box.
That's a nice looking screen you've got there! Care to share any more of it?Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by raptorsss View PostSee my signature. There is a video of my screens in action. Four years old, but just finished switching it to HS3, and in the progress of some changes. Will do another video when everything is up and running again.
That's fantastic! How did you get the buttons on the sides to move when changing screens? And where did you scare up the graphics?Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostThat's fantastic! How did you get the buttons on the sides to move when changing screens? And where did you scare up the graphics?
They way I did it was to create screen 1 in photoshop, then on screen 2, shift the buttons over a little, then again and again, for a total of 8 screens. Where screen 1 is the main screen and screen 8 has the movement in its final location. On screen 1 in HS touch, I have transparent buttons over the photoshopped buttons. When clicking he transparent button it launches a homeseer even that shows screen 2, then screen 3, etc all the way to 8. When it gets to 8, it stops, and screen 8 has new transparent buttons over the photoshopped image again in the new location.
If you were using a generic screen, and all your buttons were real HS touch buttons, you would do the same, but you would have to shift every button on each screen. More work, but would still work. And this is what i used in the example screen on the following post.
discussion on the homeseer board here. http://board.homeseer.com/showthread.php?t=148218
Graphics are a mixture of things found online and blended, and framed in photoshop.
I was able to get Pandora going inside a frame and stream out to my Airplay receivers via Airfoil. I have a button setup to launch Airfoil and luckily, it launches at the same screen coordinates is was at when it was last closed. I think I should be able to setup an event to launch airfoil that is triggered by the Pandora screen being opened.
How can I make the action to check if an application is already running and if so, bring forward... if not launch?
