BLLock beta
    #61
    Any news on having more control from the locks and users from HS?
    Transitioning to HS3Pro .298 - WinXPEmbedded
      #62
      Nope. Waiting on HST to add the API capability to HS in order to do this.
      Cheers,
      Bob
        #63
        going to try plug-in on new model schlage deadbolts
        homeseer will not update due to an association problem
        Part # is BE469NX-CAM-716
        http://board.homeseer.com/showthread...hlight=schlage
        Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
          #64
          Did Homeseer add this in HS3?
            #65
            It is on their list. I hope they do it shortly as this would be a great feature to have
            Cheers,
            Bob
              #66
              ** HS3 VERSION ** User Code translation
              I am running the HS3 version of the plugin.
              against my Yale lock (I only have one) it gives me a button USERS.
              that lists no users, and there is no way to add a user name to be used instead of the lock code when the lock is used.
              Can I add users directly into its ini file or does the HS3 version not support the translation?
              Simon
                #67
                You should be able to add users to the lock in the plugin only. It will not transfer it to the lock. I really hope HST adds this because it will open a lot of opportunities.
                Make sure you add the users in the order they are added in the lock
                Cheers,
                Bob
                  #68
                  If I click the USERS button next to the lock on the LOCK tab, it only lists (no) users.
                  there is no active button to add any others.
                  is it hiding from me somewhere else?
                  I am using a windows 8 PC to access HS3 on a windows 7 X64 PC
                  Simon
                    #69
                    Hmmm there should be an add button. Very odd.
                    Cheers,
                    Bob
                      #70
                        #71
                        Have you run the script in this thread and posted you results?
                        http://forums.homeseer.com/showthread.php?t=161081
                        Can you do it again because I updated the script to get more info about the lock.
                        I will then check when I get home to see if your lock has been added into the plugin.
                        Post the result log in the above thread.
                        Cheers,
                        Bob
                          #72
                          Bob
                          done. for the record, I had to edit the script (to remove the import of HomeseeAPI now that is automatic) before the script would run.
                          I hope it gives you all the information you need.
                          Simon
                            #73
                            OK I will fix that.
                            I will check the log tonight
                            Cheers,
                            Bob
                              #74
                              hslock plug in users disappear when restart homeseer
                              im on the latest hs3 3.0.0.38 with the latest 1.0.0.12 and still having issues where the user data disappears when i restart homeseer or reinitialize the locks. i have 2 of the kwikset locks and when they are programmed they work fine. my only issue is the darn user data. i setup 4 users on both locks, tried reinstalling plug in with deleting all files of hslock with no help. what am i doing wrong or what am i missing?
                                #75
                                I believe the newest build should fix this
                                Cheers,
                                Bob
