Originally posted by kenrad
View Post
Jon00 Homeseer 2 - Homeseer 3 - Homeseer 4 Connector
First of all thanks alot for this plugin, this is what I was missing to get started with HS3.
I am having an issue syncing the values from my Everspring Humidity and Temperature sensor from HS3 to devices in HS2.
In HS3:
Status: 73 = Dim
Value: 73 = "73%"
String: (empty)
The script correctly creates the new devices on HS2 but no matter what I put under PARM3 I don't get the 73 or 73% in HS2, only the following:
Status: 17 = Unknown
Value: (empty)
String: (empty or broken image depending on PARM3)
I have HS2 devices displayed in HS3 and they are working great.
Mathieu
Jon,
Great idea, thanks for providing this.
But I am having a problem getting it working. The HS3 gateway starts up (I can see it running in task manager) and then immediately shuts down with no errors and nothing in the HS3 log. I am running HS2 and HS3 on the same machine. I just downloaded it again to make sure I had the newest version.
Bill
Bill:
Had a similar problem. Is it connecting with HS3? I had screwed up the IP address in the settings file and it would drop out. Actually the first version Jon had accidently hard coded the IP address, but since version 1.1. (I think) it has worked great for me.
Hope you get it working. It's a great help.Don
Originally posted by mathd View PostFirst of all thanks alot for this plugin, this is what I was missing to get started with HS3.
In HS3:
Status: 73 = Dim
Value: 73 = "73%"
String: (empty)
Value: (empty)
Mathieu
Bill
mushkin92
Jon,
I mirrored HS2-> HS3 devices but i can't control them (I certainly misunderstand something...)
mushkin92
Jon,
For exemple, un hs2 a x10 device has On, Off and Dim controls. But in hs3 the controls are not present (status only)
Regards
Envoyé de mon Nexus 4 en utilisant Tapatalk
OK so What I am trying to do with the HS2 HS3 connector is have Hs3 plugins trigger events in HS2 how vdo I go about setting this up. I am hoping to integrate the Kinect plugin and BLGdata to the mix
Please help
Cheers KenHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Yes that is correct. The connector only makes a copy of the Homeseer 2 device in Homeseer 3 and updates it when there is a change. You then setup triggers via Homeseer 3 events on changes if you wish.
If you are trying to control X10 installed on Homeseer 2 from Homeseer 3, you will need to create your own virtual devices (in Homeseer 3) and then mirror them in Homeseer 2. You can then act on those changes via Homeseer 2 events.
