When clicking on the real-time log button in the plugin on my Linux HomeSeer server I get a 404 error. The problem has something to do with case sensitivity. Interestingly, navigating to the URL /bllock works, but /BLLock does not, even though the directory on the server is named BLLock.
Can't access real-time log (Linux)
Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.Tags: None
Guest
I'm having this same issue but accessing /bllock/bllock_activity.aspx doesn't seem to work for me?
Have seen same error since I installed BLLock.
Starting up BLLock navigates to http://ipaddress/bllock - all lower case.
Selecting Real-Time Log navigates to http://ipaddress/BLLock/BLLock_activity.aspx which gives a 404 System.Web.HttpException The resource cannot be found error.
Interesting - navigating to http://ipaddress/bllock/ gives a 404 Bad Request /bllock/ error. (Adding the / at end of url causes this)
