inasmuch as one can now program user codes via events, I'm assuming that HST has revealed this functionality to plug-ins too?
Any update to program user codes?
Originally posted by Blade View PostI have emailed Rich many times on this and even put in a feature request but I am not sure this will happen. It is too bad because the functionality is already in HS3 - it is just a matter of exposing it to the API
Everyone that wants this functionality should submit a separate bugzilla enhancement request. I've submitted one before and so has Blade, but the more people that request it, the more likely it will get actioned. The same person requesting it over and over again does not seem to work.
Cheers
Al
PS Here's what I put in mine:
Would like the ability to create and delete user codes through a script so that the code can be dynamically created and then emailed. Are the plugin's functions that allow the creation and deletion of codes in events exposed so that they can be called from a script? If so, can the required syntax be provided? If not, can these functions be exposed in a future version?HS 4.2.8.0: 2134 Devices 1252 Events
