This is probably obvious, but when trying to set up directories is the Destination folder where the backup is being sent to and the Directory the folder being backed up?
A little help, please
Originally posted by Rotech View PostWhere can you find the help doc. I tried the help button but there nothing there?
In my system there has been a real problem with many updates failing due to the file being in use. It has affected other authors plug-ins, not just Blades. The last few months, I have had to disable many plug-ins before they would update successfully. I wonder if one of yours failed and did not finish installing. Try disabling the plug-in, select it again then click Download and Install to install it again.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Thanks Randy , I haven't been doing my back stradegy so I desided to start with this. The whole backup precedures is still in my to do list.Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
