I recently upgraded from a Zee-S2 to an SEL controller. Since then, my BLLock plug-in no longer finds any locks in my system. I have reinitialized the plug-in, and tried removing and reinstalling, but the locks no longer show up.
There are no locks configured in the plug-in.
Just tried the plug-in again on my SEL (2.0.76.0) and it still reports that no locks are found. I have 5 Schlage locks (three BE468 and two FE599NX) but I have never been able to get any of them to recognize since moving to an SEL about a year ago.
The real-time log generates the following error, so I cannot attach a log of what is happening:
System.BadImageFormatException
Could not load file or assembly '/usr/local/HomeSeer/html/bin/SQLite.Interop.dll' or one of its dependencies. An attempt was made to load a program with an incorrect format.
Description: HTTP 500.Error processing request.
Details: Non-web exception. Exception origin (name of application or object): mscorlib.
Any ideas?
You will need to do the following:
1. Disable the plugin
2. Edit the hspi_BLLock.ini and change debugLevel=true
3. Save INI file
4. Restart plugin
Wait until HS has started and then disable debug logging on the plugin options page
Attach the BLLock-Detailed.log file zipped
It is in the HS3 root folder
For the ASPX page issue, delete this file
There might be a couple others as well
Got the new plug-in installed, and it now sees all 5 locks, but it isn't able to control them. I can unlock and lock in the plug-in, but nothing ever happens.
The locks work fine if triggered from the main Homeseer page.
The RTL shows that the locks were initialized, but no activity after that.
I see this error in the log
Are you blocking anything?
This is trying to make a ZWAVE JSON call to the Zwave plugin
What version of the zwave plugin are you running?
You need .193 or higher
02/15/2018 06:09:03:336 PM : v3.0.1.0 - Send_Homeseer_JSON_Request(): url --> http://localhost:80/JSON
02/15/2018 06:09:03:337 PM : v3.0.1.0 - Send_Homeseer_JSON_Request(): parm: request; value: pluginfunction
02/15/2018 06:09:03:337 PM : v3.0.1.0 - Send_Homeseer_JSON_Request(): parm: plugin; value: Z-Wave
02/15/2018 06:09:03:337 PM : v3.0.1.0 - Send_Homeseer_JSON_Request(): parm: function; value: ZwaveFunction
02/15/2018 06:09:03:337 PM : v3.0.1.0 - Send_Homeseer_JSON_Request(): parm: p1; value: networks
02/15/2018 06:09:03:337 PM : v3.0.1.0 - Send_Homeseer_JSON_Request(): parm: p2; value: null
02/15/2018 06:09:03:337 PM : v3.0.1.0 - Send_Homeseer_JSON_Request(): parameters set
02/15/2018 06:09:03:415 PM : v3.0.1.0 - Send_Homeseer_JSON_Request(): ERROR - Caught this web exception - Error: ConnectFailure (Connection refused)
02/15/2018 06:09:03:415 PM : v3.0.1.0 - Send_Homeseer_JSON_Request(): theResponse -->
