Greetings HS community! This is my first post here.
I have one question. I hope you can help.
How do you deal with Air Conditioners? AFAIK they don't connect directly to HS, but I need tu use Z-wave or IFTTT Thermostats to access cooling, heating, fans.... I would like to turn off the AC as the Window gets open using multi sensors etc....
I found some wiring diagrams and explanation about 24V 5 wires connection. But the question is. Does every AC model have those HVAC connectors that I can wire thermostat to? I guess cheap $200 AC will not provide option for 24V wired remote control, or should it? I don't seem to find it in user manuals.
How do you connect AC devices to HS? What is the best practice?
Thank you very much!
Br,
Dali
Br,
Dali
