I uninstalled bldenon and reinstalled it. I can't get it working again. I can ping the reciever and the plugin creates the devices.
I've tried several variations of deleting the devices and add it again. Reinstalled the plugin. I enabled debug and took a look at the log.
I see connection refused on Onkyo. I assume that is because this code was probably based on the Onkyo plugin not because it actually thinks it is communicating with an Onkyo reciever.
Below is an excerpt from the log. I could attach the whole thing. I also updated my reciever to the latest firmware. It is AVR-E300. I can ping the denon and access the web interface on the IP below.
i'm starting to wonder if I have the wrong port number. I've tried a few of them. Honestly I don't remember what i used when i first had it setup.
Not sure if this is an issue. But I do have two homeseers. Only one of them has the bldenon plug in enabled. Maybe if all else fails i'll try the other homeseer to see if i can get it to work.
Is my license good for both homeseer controllers?g
Receiver:
Number: 1
ConnectionType: TCP
ComPort:
IpAddress: 192.168.0.210
Port: 23
PingFailuresForDisconnect: 3
PingFailureCount: 0
RawMessageDevice:
Connected: False
Restart1TimeHour:
Restart1TimeMinute:
Restart1TimeAMPM:
Restart2TimeHour:
Restart2TimeMinute:
Restart2TimeAMPM:
ShowZone2Devices: False
ShowZone3Devices: False
11/19/2017 9:25:29 AM : v2.0.45.0 - Connect_To_Denon_Receiver(): ERROR - Caught this exception connecting to Onkyo receiver - Connection refused
11/19/2017 9:25:29 AM : v2.0.45.0 - Connect_To_Denon_Receiver() finished
11/19/2017 9:25:29 AM : v2.0.45.0 - Check_Receiver_Connection() finished
11/19/2017 9:25:29 AM : v2.0.45.0 - Check_Receiver_Restart() started
11/19/2017 9:25:29 AM : v2.0.45.0 - Receivers() started
11/19/2017 9:25:29 AM : v2.0.45.0 - Receivers(): allReceivers.length --> 1
11/19/2017 9:25:29 AM : v2.0.45.0 - Receivers() finished
11/19/2017 9:25:29 AM : v2.0.45.0 - Check_Receiver_Restart(): * Processing receiver -->
Receiver:
Number: 1
ConnectionType: TCP
ComPort:
Port: 23
PingFailureCount: 0
RawMessageDevice:
Connected: False
Restart1TimeHour:
Restart1TimeMinute:
Restart1TimeAMPM:
Restart2TimeHour:
Restart2TimeMinute:
Restart2TimeAMPM:
