So after more troubleshooting including starting over on the z-net, I think my device might be bad, I can talk to devices that are close but as soon as you get out of the direct contact it doesn't work. Programmed a plug-in outlet near the z-net and got it to connect, moved it to it's resting place, can't connect, moved it back and it connected right away.
It is almost like it can't route through other devices which doesn't make sense as I only have powerline devices installed so they should be meshing and extending. Is there a setting that forces direct communication over using neighbors?
