Unable to receive email - error in log
    Current Date/Time: 1/5/2017 11:42:27 AM
    HomeSeer Version: HS3 ZEE Edition 3.0.0.208
    Linux version: Linux HomeTrollerZEE 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 0 Days 1 Hour 55 Minutes 31 Seconds
    IP Address: 192.168.0.145
    Number of Devices: 17
    Number of Events: 92
    Enabled Plug-Ins
    3.0.0.72: HSTouch Server
    3.0.0.36: X10
    3.0.1.29: Z-Wave
    Fully functional system for past 1 1/2 years then 2 weeks ago I stopped receiving emails. Sending emails work fine. The error log is shown below. What I have done for isolation of problem:
    1. replace backup config. 2. replace entire backup system code. 3. Moved email from Gmail to POP under Yahoo. 4. Swapped Raspberry Pi 2 to another RPI2. 5. Swapped out ethernet connection.
    No change in failure. Help me isolate the problem from the error log:
    Unable to log into Gmail server: Authenticate as SSL client failed. You might be connecting to non SSL port.:Inner Exception: System.IO.IOException: The authentication or decryption has failed. ---> Mono.Security.Protocol.Tls.TlsException: Invalid certificate received from server. at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.LocalValidation (Mono.Security.Protocol.Tls.ClientContext context, AlertDescription description) [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.validateCertificates (Mono.Security.X509.X509CertificateCollection certificates) [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.ProcessAsTls1 () [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.HandshakeMessage.Proces s () [0x00000] in :0 at (wrapper remoting-invoke-with-check) Mono.Security.Protocol.Tls.Handshake.HandshakeMessage:Proces s () at Mono.Security.Protocol.Tls.ClientRecordProtocol.ProcessHands hakeMessage (Mono.Security.Protocol.Tls.TlsStream handMsg) [0x00000] in :0 at Mono.Security.Protocol.Tls.RecordProtocol.InternalReceiveRec ordCallback (IAsyncResult asyncResult) [0x00000] in :0 --- End of inner exception stack trace --- at Mono.Security.Protocol.Tls.SslStreamBase.AsyncHandshakeCallb ack (IAsyncResult asyncResult) [0x00000] in :0
    Update: Did sudo apt-get update to Linux but no effect on error. May have to re-do application so as not to depend on receiving emails. Others have indicated the same problem and no resolution was ever shown.
    Update: No resolution. Moved to new hardware (RPI V3 and upgrade to Homeseer). It works fine on email receive. Close out request for assistance.
    I have exactly the same problem. Ive never managed to get it to work.
      Same here
        Some more information. I'm using Gmail to send emails and this works without any problems for a year now. I enabled POP on the gmail account and just checked the "Check E-Mail" option. I tried both with and without SSL. Both fail all the time with the error message shown in the firtst post.
        HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.297
        Linux version: Linux HomeTrollerZeeS2 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 armv7l GNU/Linux System Uptime: 0 Days 20 Hours 14 Minutes 18 Seconds
        IP Address: 192.168.1.11
        Number of Devices: 100
        Number of Events: 63
        Available Threads: 399
        Enabled Plug-Ins
        3.0.0.74: HSTouch Server
        0.0.0.29: Pushover 3P
        3.0.6119.21453: UltraNetCam3
        3.0.1.87: Z-Wave
          Updated to the latest release 3.0.0.312, but still the same error.
          Also, the gmail account is set to "less secure". Otherwise Homeseer cannot even send emails through it.
            FYI, The option to read emails from my Gmail Account was running for me, with the same version of HS3 in my ZEE, and no changes in the Operating System. Suddenly in 2016, in the first semester, HS3 started to log the error well documented here.
            It seems to be that Gmail made changes in the way accepts access from Linux apps like HomeSeer. I don't have HS3 in Windows but is documented in other posts that they can get Gmail emails from HS3 running under Windows. In my case, even though I changed my Gmail account settings, HS3 can't get emails. There is no problem to send emails with the same account, but in this case HS connects with an SMTP Server.
            @Rich, I ran the three commands suggested by you in other posts:
            sudo mozroots --import --ask-remove
            sudo mozroots --import --ask-remove --machine
            sudo certmgr -ssl -m smtps://smtp.gmail.com:465
            But still the issue is not fixed
            I think it must be fixed getting support from Google. Please do it because this feature is very useful to take actions based on emails send with specific parameters.
            Many Thanks!
              Any news on this? I just updated to 3.0.0.368 and still see the same problem. This is a regular feature of Homeseer and I would really appreciate if Homeseer can fix this.
