Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
Old September 24th, 2017, 04:51 AM
mrhappy mrhappy is offline
OverSeer
Support for lighting colours/colour temperatures
Just wondering if there is a possiblity of making requests for the smart home skill, I and I am sure others now have lights which either are coloured or have a adjustable colour temperature (I use Ikea Tradfri bulbs - see here https://forums.homeseer.com/showpost...&postcount=107)
Would it be possible to get a change to the skill (which I know the options are in there as I have seen the SDK both supports colour temperatures and also complete lighting colours) to support these?
Old October 8th, 2017, 05:15 AM
Qbus Qbus is offline
Seer
Aeotec LED Strip
I would like to also request this for the Aeotec LED Strip. I have tried the settings to get the r,g,b,ww,cw to be adjustable with a voice command though the echo but it dosnt seem to support them.
Old December 11th, 2017, 12:45 AM
emiliosic emiliosic is offline
Seer
RGB lamp
Recently added a generic RGB Z-Wave lamp, and HS3 can control it just fine, except that the interface is a hot mess, almost unusable. There are no color integrations on the Alexa skill.
I've seen Wi-Fi and Zigbee lamps that work just fine with Alexa but setting the colors in HS3 is very cumbersome. It's simple enough with a script, but with either the Web interface or HSTouch, it's, let's say, difficult.
Alexa might be able to trigger scenes or virtual devices that change the color, but saying 'Turn the lamp red' won't work.
Old December 11th, 2017, 09:49 AM
OverSeer
Yeah it is quite frustrating and no news on whether or not it will be implemented, same with HSTouch is that there is no natural way to do it. I've been meaning to mess around with a slider with an RGB background that can change the value on a virtual device (which would be a 24 bit value) and then change the colour of a device with CAPI commands but I've not bothered yet.
In terms of Alexa integration then it to would be good, I guess HS might have issue because unless you add a load of control use pairs to a device of what value is red/blue/green etc then you would struggle. I'm sure a workaround such as a config web page to determine what RGB value you wanted as red/blue/green could work just as well.
Old December 11th, 2017, 03:53 PM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
We are working on the V3 Alexa API and it does support color control now, we have it working.
Is there a question from plugin authors on how to support this? You need to make sure you set the ControlUse property on your device that accepts the color value. The color value is stored in the ControlString property and its a HEX color code that starts with "#".
If you have your device configured like this, then Alexa and Google home will be able to control it. Google works now as of this post, Alexa will be ready as soon as Amazon approves our changes for the V3 API.
Old December 11th, 2017, 04:00 PM
OverSeer
In the time since writing this first post I have written a plugin that supports RGB bulbs (https://forums.homeseer.com/showthread.php?t=192391) which is why I asked about the SDK support. At present I have a device which has a colour picker.
I guess what I am wondering is if you ask Alexa 'set the bulb to red' then what are you doing - I've looked here https://developer.amazon.com/docs/de...ontroller.html which I am unsure is 'red' passed to HS or is Alexa deciding that red = FF0000 and then sending that to HS (which in turn is controlling the device via CAPI?)
That plugin also supports colour temperature controllable bulbs, again if you set the control use property to colorcontrol and ask alexa 'set the bulb to warm' or whatever then what is the correct way to handle this? I guess I am just struggling to understand what is passed from Alexa to HS.
Old December 11th, 2017, 04:20 PM
rjh's Avatar
rjh rjh is offline
Alexa calls us through our JSON interface, and yes, they pass the RGB color like "#FF0000" for RED. We then set that in the CAPI control ControlString property and then call into your plugin.
Old December 11th, 2017, 07:02 PM
spud's Avatar
spud spud is offline
Moderator
Rich, I can set the ControlUse to _ColorControl from code but when I try to access it from the "Status Graphics" tab it says "Not specified" and "Color Control" does not appear as a possible choice.
Testing with HS3 .391
Old December 12th, 2017, 12:01 PM
rjh's Avatar
rjh rjh is offline
If you set it, then you are ok. The UI in HS3 needs to be updated to include the ColorControl value, I see its not there. Will have it in the next update. We just recently added that.
Attachment 65070
Old December 12th, 2017, 03:30 PM
OverSeer
I have a plugin which has a root device and a number of children, one child is a control device (on / off / dim) and another child is the RGB colour picker currently - this is the code I use for the colour picker device.
                    Case 5
                        Pair = New VSPair(ePairStatusControl.Control)
                        Pair.PairType = VSVGPairType.SingleValue
                        Pair.Render = Enums.CAPIControlType.Color_Picker
                        Pair.ControlUse = ePairControlUse._ColorControl
                        hs.DeviceVSP_AddPair(ref, Pair)
                        Dim gpair As VGPair
                        gpair = New VGPair
                        gpair.PairType = VSVGPairType.Range
                        gpair.RangeStart = Integer.MinValue
                        gpair.RangeEnd = Integer.MaxValue
                        gpair.Graphic = "/images/HomeSeer/contemporary/custom-color.png"
                        hs.DeviceVGP_AddPair(ref, gpair)
                        hs.SetDeviceString(ref, CreateType.RGBValue.ToString("X"), False)
                        hs.SetDeviceValueByRef(ref, CreateType.RGBValue, False)
The device works OK to control the colour in HS and my bulb changes.
However Alexa only recognises the control device in the discovery so I can only turn it on/off from the app and cannot control the colour - can you advise please am I just not understanding this right or can the device that Alexa is controlling for colour not have a render type as the colour picker?
Old December 12th, 2017, 03:39 PM
rjh's Avatar
rjh rjh is offline
Color bulb support was added in the V3 Alexa API. We are currently testing it and hope to submit it for review this week. So right now color bulbs are not supported.
                    Case 5
                        Dim gpair As VGPair
                        gpair = New VGPair
Old December 12th, 2017, 03:50 PM
OverSeer
Right OK I think I read a bit quickly up there that you had it working meant that it was working in HS but see that you have said in the same post that you are waiting on Amazons approval for change. I shall sit patiently awaiting the approval..
Old December 12th, 2017, 04:05 PM
spud's Avatar
Moderator
Do color bulbs work with Google Home?
Old December 12th, 2017, 04:08 PM
rjh's Avatar
rjh rjh is offline
Yes, that is working now.
Old December 13th, 2017, 10:38 AM
spud's Avatar
Moderator
The RGB light is successfully discovered by GH, but I found a bug. If you try to set the color to red it correctly sends "ff0000" as the ControlString, but if you try to set it to green the ControlString is passed as "ff00" instead of "00ff00" and if you set it to blue, ControlString is "ff" instead of "0000ff".
  #16
Old December 13th, 2017, 12:59 PM
rjh's Avatar
rjh rjh is offline
This is fixed on the server, so you should see the full hex value now. Our plugin handled this ok, but I could see other plugins getting confused.
HTML code is Off
Can HSTouch do colours in Philips Hue? ryuvann Designer 2 March 20th, 2017 06:34 AM
Plugin Actions (Cell Colours) mrhappy Script & Plug-In Development 0 August 24th, 2011 05:34 PM
Insteon Lighting Plug-In v1.3 with Motion Sensor and Triggerlinc Support mnsandler Insteon Plug-in (Mark Sandler) 60 July 26th, 2010 10:51 PM
2-colours slider PSL74 HSTouch™ 2 January 9th, 2010 03:15 PM
Thermostat/Other non-Lighting Support jamesx0 ISY Plug-in Beta (3P) 5 November 9th, 2008 09:52 PM
